Hayabusa Engined Mini, Need Advice
6 replies to this topic
#1 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 24 September 2010 - 04:07 PM
im wanting to make a mini thats front engined, rwd and has a turbocharged hayabusa motorbike engine. i want it for a near everyday car but the only problem i can see it that theres no reverse gear. is there a solution to this or is it possible to put the engine on a cars gearbox?
#2 minimad01
minimad01
  • 563 posts
Posted 24 September 2010 - 04:19 PM
pro motive now do a kit for a r1 eninge witch has a reverse but its front wheel drive its not turbo an its an r1 :thumbsup:
#3 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 24 September 2010 - 04:37 PM
im wantin the hayabusa engine for the power and also cus it is alot more rare than the R1 but thanx anyway its sumthin to consider
#4 minimad01
minimad01
  • 563 posts
Posted 24 September 2010 - 04:41 PM
might be worth contacting pro motive an seeing it there revers gear setup will fit an hayabusa engine
#5 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 24 September 2010 - 04:44 PM
i will do thanx
#6 daveeeeee
daveeeeee
  • 684 posts
Posted 24 September 2010 - 06:33 PM
Otherwise you can buy an electric motor for reversing, which is quite common on bike engined cars.
#7 james753
james753
  • 219 posts
Posted 25 September 2010 - 06:49 PM
Quaife make a box to go inline with the prop shaft which reverses the drive, theoretically 6 reverse speeds.
http://www.quaife.co...products/qbe35g
see link!
Hope that helps
James
