Lower Ball Joint Stuck
7 replies to this topic
#1 chrisg
chrisg
  • 254 posts
Posted 24 September 2010 - 04:16 PM
hi guys
i am trying to fit new front wheel bearings on my 1994 mayfair
i have had to remove the lower arm to get the hub off because the ball joint pin is stuck in it and i cant separate it.
any tips?
the rubber dust cover has ripped off while i was trying to separate it am i best just leaving it and letting it gradually wear out?
will it pass mot without a rubber dust cover?
or do i knack it to get it separated and then replace it? or is it easier to cut the lower arm off it and replace that?
not sure what the best plan is :thumbsup:
#2 minimad01
minimad01
  • 563 posts
Posted 24 September 2010 - 04:22 PM
i had this problem when i was changing my engine i couldnt get the bottom undone so i had to put it all together finger tight an then let the car down onto the ground with the wheel on get underneath take the nut of so it was finger tight then lift it back up an undo it :thumbsup: by the way id change the ball joint while its of an youv got the chance >_<
#3 chrisg
chrisg
  • 254 posts
Posted 24 September 2010 - 04:27 PM
think i follow that are you saying that with the nut on the end of the pin loose the weight of the car will pull the pin out of the lower arm ?
#4 minimad01
minimad01
  • 563 posts
Posted 24 September 2010 - 04:33 PM
sorry miss read the orignal post i thought you couldnt get the bottom ball joint undone but it may work what i just said
#5 reffle
reffle
  • 80 posts
Posted 24 September 2010 - 04:53 PM
You need a ball joint splitter like this (expensive) one: http://minispares.co...ty=pb&pid=36236 you can probably find a cheaper one elsewhere
Another method is to whack the bottom arm with a hammer to try and break it free
#6 chrisg
chrisg
  • 254 posts
Posted 25 September 2010 - 10:34 AM
yeah got one of them, also have the hammer wedge type, i cant get in with the splitter screw type and the hammer one won't shift it either. grrrr
#7 mini mark
mini mark
  • 876 posts
Posted 25 September 2010 - 12:20 PM
just get as much pressure as you can on it and just try and hit it as hard as you can your best with a sissor one just have to keep at it it will come or you might have to get some heat to it but then it will need to be replaced
#8 100ev8
100ev8
  • 622 posts
Posted 25 September 2010 - 12:33 PM
dust cover is not a reason to fail mot. advice only . but better to replace it
