Edited by supermotolew, 06 October 2010 - 03:39 PM.
Posted 06 October 2010 - 03:38 PM
Posted 06 October 2010 - 03:48 PM
*sorry i mean find * hello recently i have had to remove my cover as it is wrecking my paint now i have found i have sevral leaks in the bottem left window corner is a dribble but a have one bigger one some where and i cant trace it i have taken some pics of the rough area is seems to be comming from although its hard to tell as every thging that is metal has condensation on i have tried all the usual trick sat in the car when it is raining the car has no obvious rust outside i have fitted 2 new door check seals rubber type the door seals look good is it posseble to leak through the seam out side i have photo where the 2 panels joinwhere i have put the white mark the pictures in side are bottom right andtop right on the inside by the check strap if any one lives localy gu35 bordon then theres some beer in it if you can make the rain stay on the out side even if you have to sillicone it up
Posted 06 October 2010 - 03:55 PM
Posted 06 October 2010 - 05:23 PM
Edited by j519ldv, 06 October 2010 - 05:24 PM.
Posted 07 October 2010 - 02:58 PM
Posted 07 October 2010 - 04:05 PM
Edited by Cerberus, 07 October 2010 - 04:08 PM.
Posted 07 October 2010 - 04:33 PM
Posted 07 October 2010 - 05:07 PM
