im getting a tapping noise....
15 replies to this topic
#1 Madmax
Madmax
  • 2,638 posts
  • Local Club: Grimsby & Louth MOC
Posted 06 December 2005 - 11:49 PM
Im getting a tapping noise, that increases with engine speed but isnt loud enough to be heard over 2k rpm, it sounds like a slack chain???
ive got vernier duplex timing gears/chain and the tensioner is NOT on, will this be the cause perhaps?
the engine is running fine otherwise
the only sound i can liken it to is like when something vibrates as if its off centre and it slaps the chain but not quite, its kinda wierd
took it to Sleaford Mini Centre for the rolling road, and they couldnt work out what the noise was, it doesnt sound like its a major thing, it doesnt sound like little ends and its definatley not a clunking sound, just wondering if anyones experienced the same problem?
#2 Madmax
Madmax
  • 2,638 posts
Posted 06 December 2005 - 11:54 PM
oh and its coming from the top right of the engine, all valve clearances are set to the correct gap
#3 vasi
vasi
  • 897 posts
  • Local Club: Minis 'n' Oatcakes
Posted 07 December 2005 - 12:20 AM
Top right as viewed from the front of the car? If so then timing chain is the area in which to investigate.
On the other end of the engine, could be primary gear endfloat, idler gear float or idler bearings.
#4 Madmax
Madmax
  • 2,638 posts
Posted 07 December 2005 - 08:55 AM
nah its not on the flywheel side, i had thought it was the idler or primary, but on closer inspection its coming from the other side, damn thing wont start now
#5 Jammy
Jammy
  • 25,397 posts
Posted 07 December 2005 - 08:58 AM
Tapping noise in your engine? That'll be Michael Flatly in your rocker cover!
#6 Madmax
Madmax
  • 2,638 posts
Posted 07 December 2005 - 08:59 AM
that lucky ghets made a billion from riverdance y'know
#7 Jammy
Jammy
  • 25,397 posts
Posted 07 December 2005 - 09:16 AM
*Sticks on his dancing shows and hopes, rather ambitiously, to make £10*
#8 minimole
minimole
  • 781 posts
Posted 07 December 2005 - 10:07 AM
i give you a tenner to watch you (try to) dance :thumbsup:
#9 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 07 December 2005 - 06:40 PM
Are you still using the mechanical fuel pump. I found these to make a tapping noise that is irritating rather than a problem :thumbsup: The reason being that at low rpm the engine is not using very much fuel and the float valve in the carb shuts off so the pump is now idling, so to speak, wich is why it dissapears at higher rpm.
#10 Madmax
Madmax
  • 2,638 posts
Posted 07 December 2005 - 07:01 PM
this had crossed my mind, yeah im still using the mech pump... i shall see if i can get hold of a decent microphone and try post up the noise...
it doesnt seem to do it when its cold either...
#11 Purple Tom
Purple Tom
  • 4,921 posts
Posted 07 December 2005 - 08:22 PM
that kinda suggests that its possibly some sort of lubrication problem - ie - when the oil is thicker its lubricating whatever is rattling, and as it warms and thins then the noise rears its head as whatever's rattling stops receiving as much lubrication?
Daft question, not your rockers hitting the rocker cover? (actually no it can't be else the noise wouldn't disappear above 2k - ignore that)
#12 Sprocket
Sprocket
  • 7,266 posts
Posted 07 December 2005 - 08:24 PM
Isolate the noise by using a long screwdriver with a big handle. Place the tip against the engine at areas where you suspect the tap is coming from, place the handle end against the little flappy bit infront of your ear above the ear lobe, push this flapy bit with the handle into the ear and seal off the ear hole. This way converting the screwdriver into a stethascope.
Sounds totaly daft but is very effective and costs less than a stethascope, unless you don't own a screwdriver :grin:
#13 Sprocket
Sprocket
  • 7,266 posts
Posted 07 December 2005 - 08:25 PM
Oh and i'm sure you'll find that it's the fuel pump :cheese:
#14 Madmax
Madmax
  • 2,638 posts
Posted 07 December 2005 - 08:38 PM
well im not so sure it disapears, could more be drowned out...?
i have thought about the rockers hitting the cover and ive removed and replaced the cover...
still does it :thumbsup: lol
#15 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 09 December 2005 - 01:40 AM
Its the mouse in you engine, its trying to get out!
