Engine Cut Outs At Low Revs
Posted 06 October 2010 - 09:25 PM
1993
Hi guys, i have just bought a 93 cooper and am now having some problems.
Initially the car started fine and ran well, but after about 2 miles started to become a bit jumpy below 2500 revs. It then got to the point where the engine cut out at low revs, The engine wouldn't start although i managed to get it going again with a jump start.
All the time the revs wee kept higher than 3k the car ran perfectly but as soon as i let the revs drop the car would cut out. Had the bonet up second time and neither myself or my mate could see anything obviously wrong. Though when trying to turn the engine over it did cough up a great black cloud from the air filter.
Before i bought the car it had been SORN for 3 years, all though it was taken out for it's mot every year last MOT was September and it passed needing no work. The battery had been disconnected and fully charged while the car was off the road.
Does anyone have any idea what this problem might be.
Thanks in advance
Phil
Posted 06 October 2010 - 09:42 PM
but it wouldnt by chance be the choke?
i have one on my bike and quite often if you start it from cold without the choke it will cut out when you get to low revs.
i cant even remember if rover minis have chokes or not?
Posted 07 October 2010 - 01:25 AM
David.
Posted 07 October 2010 - 05:08 AM
Failing that check all the leads/plugs/dizzy are ok and clean/replace if necessary.
Hope this helps
Posted 07 October 2010 - 06:14 AM
will have a look at the air filter. Have driven choke cars before so prety sure it's nothing to do with that.
thanks again for getting back to me
Posted 07 October 2010 - 06:29 AM
Posted 07 October 2010 - 06:33 AM
Good Luck Mate
Posted 07 October 2010 - 07:23 AM
Do you have access to a compression tester. I blew a head gasket between 2nd and 3rd which behaved similarly. It would have poor compression from leaking through to the other cylinder but when it got up in the revs there wasn't enough time to force all that air through so it appeared to run smooth. Just a theory for yours and I hope its not that. Tell us what the problem is when you discover it and we'll all learn something
Good Luck Mate
Hi Miniguy,
Not got access to anything remotely mechanical, although i'm pretty sure it's nothing like that. The car was only MOT'ed last month and hasn't been run since. apart from a quick drive back from the body shop, as it hadn't been taxed.
This was it's first proper outing in a couple of years and to be honest i only did about 5 miles tops.
Everyone else keep the suggestions rolling in and i'll report back with anything i find out
Posted 07 October 2010 - 05:16 PM
Posted 12 October 2010 - 10:34 AM
a mate of mine who knows what he's doing.
pulled a cable off the thing in the picture, squirted it with wd40 and twenty seconds later i had a happy perfectly functioning car.
Cheers for all the help though
Posted 12 October 2010 - 02:01 PM
