Model: Rover Mini Sprite
Year: 1992
Description of problem (please be as in depth as possible): I've just drained the oil from my car and bloody hell it was black!! And wow that magnet was caked in metal!!
ANYWAY - I've got the type of oil filter that's external and is disposible. . . Tried holding it tight and twisting + with a rag around it + with a screw driver through it.
Apart from using a specialist tool (Which I don't have), Are there any other home methods?
(I can only get the screw driver just over half way in)
Thanks! Kai
Oil Filter Removal Tips?
Kaison
, Oct 09 2010 11:32 PM
4 replies to this topic
Posted 09 October 2010 - 11:32 PM
Posted 10 October 2010 - 12:15 AM
try banging the screwdriver all the way thro, make sure its need the end of the filter. Then just wind it off, it shouldn't be too tight o make sure you are turning it the correct way, anticlockwise.
Posted 10 October 2010 - 12:56 AM
I brought a engine and the idiot had done it up so tight, the oil filter housing snapped in two when I tried to take the oil filter off, I've heard of sand paper being used, but generally I use ram a screw driver through it. You can get a screw driver and put it at the top on the ring and bang it with a hammer in a way that it slightly moves the filter around and just keep doing that to loosen it slightly.
Posted 10 October 2010 - 04:03 AM
If you use a strap, try tightening it slightly first, then undo
Posted 10 October 2010 - 08:21 AM
use one of the cup type sockets that fits over the base of the filter
