Sill Replacement
Posted 10 October 2010 - 06:44 PM
The car currently has oversills which are rotten through on passenger side.
I want to remove these oversills and the remains of any of the original sill that is left.
Question is for the replacement should I use an oversill type again that folds round and welds to the floor??
or the original type with open vents?
After poking holes with a screwdriver all over the current sills were full of water.
Anyone know the correct parts from mini spares etc??
All advice appreciated
Cheers all
Andy
Posted 10 October 2010 - 06:51 PM
Posted 10 October 2010 - 06:57 PM
Not good news i'm afraid, oversills are well known for hiding rust although if done well then they would do but obviously not in this case. Due to them not having vents in them they will collect moisture and lead to rust.
Edited by sonikk4, 10 October 2010 - 06:58 PM.
Posted 10 October 2010 - 07:41 PM
At the time the outer cover sills were still solid so weren't replaced. Wish I had done them now.
Posted 10 October 2010 - 07:52 PM
I know they are easier to fit, but they will never be any good for the car in the long run
Posted 11 October 2010 - 07:56 AM
Posted 11 October 2010 - 08:11 AM
Then just go round with a grinding disk and clean up.
Posted 11 October 2010 - 04:34 PM
the only 4 1/2" ones I can find are the non genuine type
Only genuine ones I have seen are 4" only.
Is this correct?? As I would prefer genuine only as reproduction ones always seem to be poor quality thin steel.
Edited by I could eat a horse Haha, 11 October 2010 - 04:35 PM.
Posted 11 October 2010 - 05:00 PM
fit the 4" one and do the repairs as required
as for ease of fitting the standard sill is easiest because its what they came with, remove and replace
dave
Posted 11 October 2010 - 06:43 PM
Posted 18 October 2010 - 06:19 PM
Fairly extensive!!! - the lazy git that fitted over sills wants shooting.
This may take some time.....
Posted 18 October 2010 - 06:30 PM
JR
Posted 18 October 2010 - 06:32 PM
I like to have the wheels on and put them onto large crates to stop the shell moving whilst it's all cut about. Then do the inners, followed by the outers. If you can beg or borrow a spot-welder it makes it so much easier. Heritage or original genuine panels are the best and if you can keep it as manufactured it is always good. Don't forget that you may need new jacking points which may come with the new inner sills.
Posted 18 October 2010 - 06:35 PM
I have a large sheet of steel, line bender, hammer and dolly. will be making the panels myself.
Only one i have bought so far is the outer sill itself.
Also yes hopefully have a spot welder on its way from a friend. Failing that will hire one from HSS. Got to be easier than gringing back all those plug welds.
Big job broke out me thinks!!!
Edited by I could eat a horse Haha, 18 October 2010 - 06:40 PM.
Posted 18 October 2010 - 06:45 PM
At least you know it will fit making your own.
