Spark Plugs For 1275 Stage One
54 replies to this topic
#1 Carlzilla
Carlzilla
  • 1,907 posts
  • Local Club: Splinters Mini Club
Posted 11 October 2010 - 03:31 PM
what are the best ones to get?
#2 Mal_whitby
Mal_whitby
  • 82 posts
Posted 11 October 2010 - 03:35 PM
NGK BP6ES or the Champion equivalent - i.e. standard plugs, no need to go to 7's or any other for that stage of tune.
#3 Carlzilla
Carlzilla
  • 1,907 posts
Posted 11 October 2010 - 03:54 PM
Cheers, wasnt sure if there was anything better out on the market
#4 Czar
Czar
  • 26 posts
Posted 11 October 2010 - 04:51 PM
there are better designed spark plugs with Silver for the core, Silver is the best electrical and thermal conductor.
#5 miniallsort
miniallsort
  • 4,723 posts
Posted 11 October 2010 - 04:55 PM
bosch super 4 core are pretty good
Edited by miniallsort, 11 October 2010 - 04:56 PM.
#6 Wil_h
Wil_h
  • 3,244 posts
Posted 11 October 2010 - 05:40 PM
The onlt thing that can be better about a spark bug is reliability and service life. I find NGK to be more than up to the job. No point spending loads on more exotic plugs claiming better conductivity as a modern resistor plug has a fixed resistance, so you're just chucking money away.
And whatever bloke down the pub says, spark plugs will not inprove the performance of your engine. Any test that shows they do is flawed, most likely using knackered plugs to start with.
#7 Carlzilla
Carlzilla
  • 1,907 posts
Posted 11 October 2010 - 05:51 PM
Good job i dont go down the pub very often then!
#8 samsfern
samsfern
  • 5,243 posts
Posted 11 October 2010 - 05:55 PM
try ngk bp6es's as a starting point. Then maybe go to bp7es's. If im right the spi coopers use 7's?
#9 Czar
Czar
  • 26 posts
Posted 11 October 2010 - 06:01 PM
Do you want a lesson in Spark plug technology ?
#10 Carlzilla
Carlzilla
  • 1,907 posts
Posted 11 October 2010 - 06:03 PM
Hmm, according to halfrauds, using my REG it came up as me needing Bosch super 4's or the Bosch +1 super plus plugs
And for a 1.3 carbed non turbo it came up as me needing Champion EON 6 plugs
From what they stock.
Arent they exactly the same threaded plug anyway?
Also, whats with Bosch putting super in front of everything? :S
Edited by Carlzilla, 11 October 2010 - 06:04 PM.
#11 samsfern
samsfern
  • 5,243 posts
Posted 11 October 2010 - 06:06 PM
ngk bp6es's from a motorfactor will be fine, and less than half the price halfords will charge.
#12 pikey7
pikey7
  • 3,824 posts
Posted 11 October 2010 - 06:07 PM
you mean it was trying to overcharge you? Shocker!!!
#13 Carlzilla
Carlzilla
  • 1,907 posts
Posted 11 October 2010 - 06:08 PM
Had those in my 998 and they worked well, got some champion plugs in the 1275 and im not very impressed with them, not sure how old they are though, but they look pretty new to me.
Which was why i asked in the first place, to see which people thought were a better spark plug
#14 samsfern
samsfern
  • 5,243 posts
Posted 11 October 2010 - 06:10 PM
we kept havingb problems with the champion plugs at work, so we switched to ngk's, and havent had any problems.
#15 Carlzilla
Carlzilla
  • 1,907 posts
Posted 11 October 2010 - 06:13 PM
Yeah, noticed the engine quite lumpy at times, wont run very well if its running at 1.7% on emissions, but ran ok when it was at 10.5%, which is way too much and hurts the pocket a bit.
the coil is new, the leads are new, the dizzy cap and rotor are new, so it just leaves me down to the plugs i guess causing the lumpyness
