Edited by union jack, 14 October 2010 - 06:03 PM.
Removing Doors
Posted 14 October 2010 - 06:03 PM
Posted 14 October 2010 - 06:12 PM
worth a shot for you too
Posted 14 October 2010 - 06:23 PM
2 studs per hinge (4 in total) soak them with plusgas or simmilar before you try to undo them, the studs can snap if the nuts are tight.
Posted 14 October 2010 - 06:39 PM
It was easy enough sorted as i found out that the original studs are a metric 6 thread. Ground off the blob of factory weld and the studs just screwed out.
Refitted new studs and rewelded them.
Posted 14 October 2010 - 06:45 PM
Posted 14 October 2010 - 06:53 PM
Just done this on my 95 Sidewalk. Tried soaking with penetrating fluid and wire brushing but i still managed to break 3 studs on the one side.
Are you sure they are M6? They should be 1/4" UNF.
Posted 14 October 2010 - 06:57 PM
on my 91 city i had the same problem and resorted to loosening the nuts through the wheelwell in behind the a-panel.... worked a treat.
It generally works a treat when you resort to doing things the proper way!
Posted 15 October 2010 - 04:44 AM
Posted 15 October 2010 - 05:00 AM
Posted 15 October 2010 - 08:28 AM
