Wheel Offset?
Posted 15 October 2010 - 04:56 PM
im looking into buying a set of 13 inch wheller wheels, which are currently fitted to an austin healy sprite.
the guy that im possibly buying them from said have a made sure that the offset of the wheel is correct :s
can somebody give me some insight into wheel offset-ness:P?
and if anyone has the million doller answer, will they fit would be good to:P:)
thanks
Posted 15 October 2010 - 05:25 PM
hi,
thanks
Basically it's how far the point that joins to the hub of your wheel, is from the centre of the wheel line. Deep dish wheels for example would have negative offset.
Hope this helped.
Greg.
http://www.theminifo...?showtopic=6750
with pictures and everything!
Posted 15 October 2010 - 09:08 PM
Posted 18 October 2010 - 07:13 AM
mra, im unsure on tyres at the moment as i dont know how good the tyres are on it.
would they need to be quite low profile to fit under the mini arch?
thanks
Posted 18 October 2010 - 07:18 AM
Posted 18 October 2010 - 01:25 PM
Posted 18 October 2010 - 04:22 PM
thanks
Posted 18 October 2010 - 07:30 PM
I have previously fitted 175 60 13" on to the front and rear of a mini, makes it very tall in the gears, but pretty good results.
Sorry I had better add that you would need to do some work on the radius arms and the brackets.
Edited by mra-minis.co.uk, 18 October 2010 - 07:31 PM.
Posted 18 October 2010 - 08:20 PM
Posted 19 October 2010 - 05:16 AM
