Oil Smells Of Petrol ?
9 replies to this topic
#1 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 16 October 2010 - 06:29 PM
hiya think i have oil in the petrol im quessing this is wroung and have been told it may be the fuel pump is this correct ???
#2 jonny d
jonny d
  • 1,148 posts
Posted 16 October 2010 - 06:50 PM
I had the same problem on mine and it was the fuel pump the oil was so thin it peed out of the clutch housing ,and clutch slipped like crazy very dangerous to drive the car like it you could granade your motor
#3 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 16 October 2010 - 06:52 PM
ok so fuel pump should i get a new one or just get a second hand one ???
#4 Cerberus
Cerberus
  • 989 posts
Posted 16 October 2010 - 07:18 PM
If it was me, I'd replace it with an electric one.
Much more reliable, and has no dependency on the engine.
#5 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 16 October 2010 - 07:26 PM
how much more expensive are they and whats the ads n disads ??
#6 Cerberus
Cerberus
  • 989 posts
Posted 16 October 2010 - 07:30 PM
Depending on which fuel pump you get, the electric ones can be anywhere from £10 more than a mech up to £50 more.
Minisport fuel pumps
I don't think there are any disadvantages to having an electric fuel pump over mech.
#7 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 16 October 2010 - 07:33 PM
thanks i dont have much money as mo and the normal one being only 15 think im gonna have to go with that as its all i can afford whats the ads of the electric pump ???
#8 1984mini25
1984mini25
  • 8,787 posts
Posted 16 October 2010 - 07:39 PM
It will only cost ya, a fuel pump (best to stick with what there) 2 gaskets, maybe some fuel hose clips if they’re crusty and an oil change.
If oil getting on the clutch to cause it to slip, it sounds like the primary gear seal behind the flywheel has failed.
#9 Cerberus
Cerberus
  • 989 posts
Posted 16 October 2010 - 07:40 PM
Well, they're more reliable IMO, the mech one will be fine for a standard engine, and if its a new one, should last ages anyway.
They can provide a better fuel supply too, but probably only needed for more tuned applications.
So yeah, if you budget limited, the mech one will be fine.
#10 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 16 October 2010 - 07:43 PM
yh im keeping it stadard apart from the stage 1 kit already on it next year will be fitting a 1275 so should be fine :D
