S/c Drops Ratios
5 replies to this topic
#1 1977 Loud_Mini
1977 Loud_Mini
  • 896 posts
Posted 16 October 2010 - 07:37 PM
Hi all, just wondered if anyone knows if a 24 tooth top gear, 24 tooth middle gear and 30 or 31 tooth bottom gear as arranged on the gearbox is the 1:1 standard drop/transfer gear ratio? The reason i ask is because the person selling them hasn't really stated what the ratio is and hopefully someone on here can help me out.
Thanks, Evan.
#2 pikey7
pikey7
  • 3,824 posts
Posted 16 October 2010 - 07:44 PM
the idler doesn't affect the ratio. the primary and input gears should have the same teeth for 1:1, so 24:24 is..... :D
#3 1977 Loud_Mini
1977 Loud_Mini
  • 896 posts
Posted 16 October 2010 - 07:49 PM
the idler doesn't affect the ratio. the primary and input gears should have the same teeth for 1:1, so 24:24 is..... :)
Ah right that makes sense :D
but what about 23/23 gears, i thought that a 24/24 gave a different ratio to 23/23?
#4 pikey7
pikey7
  • 3,824 posts
Posted 16 October 2010 - 07:50 PM
23:23 is slightly smaller than 1:1 :D
#5 1977 Loud_Mini
1977 Loud_Mini
  • 896 posts
Posted 16 October 2010 - 07:52 PM
Thanks for the help, so 24/24 should be fine for what i want then.
#6 pikey7
pikey7
  • 3,824 posts
Posted 16 October 2010 - 07:54 PM
23:23 IS 1:1!
the most common are 24:24 or 24:23 which gives a slight raise of 1.04:1, so yeah, 24:24 is fine.
