Oil Gauge
4 replies to this topic
#1 andrew1986mini
andrew1986mini
  • 103 posts
Posted 17 October 2010 - 07:28 AM
rover 998 1990
was working on my dizzy cap yesterday and i noticed a sender unit sticking out of the engine just to the left of the dizzy i know this aint the tmp sender unit because that is on the right next to the thermostat housing so what could this be only gauges i have in the car are fuel and temp
ill try get a pic uploaded today if it helps any one
#2 mikey72
mikey72
  • 321 posts
Posted 17 October 2010 - 07:33 AM
Oil pressure warning light.
#3 andrew1986mini
andrew1986mini
  • 103 posts
Posted 17 October 2010 - 07:37 AM
ahh make sense =] cheers
#4 Carlzilla
Carlzilla
  • 1,907 posts
  • Local Club: Splinters Mini Club
Posted 17 October 2010 - 09:20 AM
Yup thats the oil pressure sender switch, if youre fitting an auxiliary oil pressure gauge, use the t piece supplied, and refit the oil pressure sender, I think in the event of any lack of oil pressure, its much easier to see a light on the dash than it would be to look over at a gauge, as most of the time you wont be looking at it anyway =]
#5 GreenMini17
GreenMini17
    Formally known as Chris-G
  • 424 posts
Posted 18 October 2010 - 09:40 AM
Its probably worth while fitting a higher pressure warning light whilst you are fitting the gauge. The standard one comes on at like 7 psi, which your engine is nakard by then anyway!
