Want To Get Twin Carbs And Stage 1 Kit
Posted 18 October 2010 - 04:15 PM
the engine is completely standard and i am wanting to get twin carbs and a stage 1 kit.
what size twin cabs do i need?
i have seen some on ebay with the whole lot for around £150-£200 including the manifold.
will i need to split the fuel line into 2?
do i need the whole stage 1 kit, because i cant find one for a twin carb?
Posted 18 October 2010 - 04:30 PM
Ben
Posted 18 October 2010 - 04:47 PM
I hope this helps to clarify things for you.
Posted 18 October 2010 - 05:11 PM
Posted 18 October 2010 - 05:28 PM
Posted 18 October 2010 - 05:32 PM
Posted 18 October 2010 - 05:35 PM
Posted 18 October 2010 - 05:38 PM
If you can get the 998 engine to a 998 Cooper spec, then twin HS2's would be good so long as you have them set-up properly. The key is the head and cam plus the exhaust system. Don't bother using the term 'Stage 1' as it really doesn't mean a lot.
Posted 18 October 2010 - 05:41 PM
Posted 18 October 2010 - 05:43 PM
The 997 & 998 Coopers all had twin HS2's as standard, that's 1.25", and with the open-chamber head with its slightly larger valves and 3-branch manifold they went well in their day. Even the original Cooper 'S' had twin HS2's. IMHO twin 1.5" carbs are not good for a 998 as they are just too big. The only 1000 cc engine I've used twin 1.5's on was a 970 Cooper 'S at full competition spec which revved to 8000 and needed the bigger carbs to get the mixture in at those revs. It gave 88 bhp at 7000+.
Posted 18 October 2010 - 05:48 PM
Edited by bmcecosse, 18 October 2010 - 05:49 PM.
