Maximum Bore Size
10 replies to this topic
#1 Slinky1313
Slinky1313
  • 197 posts
  • Local Club: Sutton Mini Club
Posted 18 October 2010 - 04:52 PM
hey all, just curious, i was under the impression that the largest you could bore the cylinder of a standard metro engine was 1380, and even that was pushing it, after that the walls are to thin? yet im just watching this http://www.youtube.c...feature=related where he says he has a 1430. but it looks like a standard block. just a little confused lol. Thanks all
#2 samsfern
samsfern
  • 5,243 posts
Posted 18 October 2010 - 04:54 PM
1430 is a 1380 bore, which has a modified crankshaft to increase the stroke (how far down the bore the piston travels), thus increasing ccs.
Edited by samsfern, 18 October 2010 - 04:58 PM.
#3 Slinky1313
Slinky1313
  • 197 posts
Posted 18 October 2010 - 04:57 PM
1430 is a 1380 bore, which has a modified crank to increase the stroke (how far down the bore the piston travels), thus increasing ccs.
aaaaa brilliant, thanks, just coundnt wrap my brain around it lol.
#4 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 18 October 2010 - 05:00 PM
Ah yes.. But if you have straight bored a 1275 block you can go to 74mm bore...73.5 being 1380cc
#5 DAVEY_C
DAVEY_C
  • 555 posts
  • Local Club: irish minis owner club
Posted 18 October 2010 - 05:09 PM
i understand about the rebore and stroke and would that be an 81mm stroke then.... could you put an 1100 crank into a 998 to increase the stroke or does it not work like that??
on a stroked crank, does the piston not rise the same distace as down and so would need a skim off the top of the piston to stop it rising past the block surface?? how would that effect the piston action or would it??
sorry im not hijacking the thread but just trying to get more info on the topic for us....
#6 samsfern
samsfern
  • 5,243 posts
Posted 18 October 2010 - 05:12 PM
i think itll be an 84mm stroke, youll need to use "s" rods, as the journals smaller, and yes, the pistons will need machining as theyll sit proud of the block.
#7 pikey7
pikey7
  • 3,824 posts
Posted 18 October 2010 - 05:15 PM
1425 uses a 74.7mm piston. can be stroked to 1595cc.
it's a handgrenade with the pin out though...
#8 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 18 October 2010 - 05:20 PM
Lots of torque and power......untill it goes bang!!! I wonder if thats why no one builds them??? Well not many anyway...
#9 KieronBoz
KieronBoz
  • 280 posts
  • Local Club: LMCC
Posted 18 October 2010 - 05:56 PM
who wants to explain what boring is?
#10 Dan6061
Dan6061
  • 761 posts
  • Local Club: -
Posted 18 October 2010 - 07:54 PM
Increasing the size of the cylinders and pistons, thus increasing the engine size. :thumbsup:
#11 Wright&Wright
Wright&Wright
  • 309 posts
  • Local Club: Central Mini Owners Club
Posted 18 October 2010 - 07:55 PM
1100 engines ARE 998's with a stroked crank. They're the same block, different crankshaft. :thumbsup:
It's the machining of the cylinder walls to increase their diameter and therefore overall displacement. :D
