Where Is The +12 Volt Switched Supply
7 replies to this topic
#1 WorksReplica
WorksReplica
  • 26 posts
Posted 18 October 2010 - 06:48 PM
As described where am i able to find the +12 volt switched supply so i can wire up a rev counter, i am new to all of this so pictures will help me dearly.
I have a 1989 austin mini if that helps at all.
Thanks to anyone in advance!
#2 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 18 October 2010 - 06:55 PM
Four fuse block layout
2nd fuse down (25amp) is constant live
3rd fuse down (25amp) is switched live
Hth
#3 WorksReplica
WorksReplica
  • 26 posts
Posted 18 October 2010 - 06:58 PM
Thanks for the quick reply! Just to say, switched live is what i'm looking for. When you say 3rd fuse down, do you mean the 3rd fuse down in the fusebox on the bulkhead?
Thanks again
#4 Kam
Kam
  • 4,140 posts
Posted 18 October 2010 - 07:20 PM
Yep third fuse down as you look at it straight on
So from top to bottom its 35, 25, 25 and 15amp
Each end of the fuse holder is numbered 1 to 8 so top fuse is 1 and 2, second one down is 3 and 4 etc but its referred to as the four fuse block layout
#5 bmcecosse
bmcecosse
  • 9,699 posts
Posted 18 October 2010 - 08:05 PM
Switched by what ???
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 18 October 2010 - 08:22 PM
Your car is already wired for a tacho. If it wasn't built with one, the wires are taped back to the wiring loom behind the dash.
#7 Kam
Kam
  • 4,140 posts
Posted 18 October 2010 - 08:27 PM
Use the third one down (switched live) the green with orange trace in my pic is the standard usage for rev counters, as Dan said its sitting behind your dash already along with a white with black trace bullet connector if the wiring has been untouched
#8 WorksReplica
WorksReplica
  • 26 posts
Posted 19 October 2010 - 09:06 AM
thanks guys, well initially i made a wire and connected it to an empty spade terminal on the third fuse down (switched live) the rest (guage to negative coil etc) and earthed. but the gauge only works when i flick it or tap it? can't understand what that means, i bought the gauge as recondtioned from 'the gauge shop' online, but could this mean at all i have a faulty earth perhaps?
thanks everyone for your help, i'll try and find the green cable with orange trace, connect that up and see if anything improves!
