Tow Strap
9 replies to this topic
#1 Minii_Matt
Minii_Matt
  • 55 posts
Posted 20 October 2010 - 01:50 PM
Hi,
I'm looking at buying a tow strap for my mini to make it easier should it be needed to be towed. I was just wondering if anyone already had one of these and if so, where is it attached on the car?
Also, could a tow eye like this be fitted anywhere to a mini as an alternative?
Thanks in advance,
Matt
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 20 October 2010 - 01:51 PM
i thought you had to use a ridged bar
#3 miniman retford
miniman retford
  • 3,553 posts
Posted 20 October 2010 - 02:04 PM
MRA mini's do a towing eye to replace the front subframe mount bolt
http://www.mra-minis...-made-in-uk.htm
#4 Carlos W
Carlos W
  • 10,114 posts
Posted 20 October 2010 - 02:07 PM
I think this is the case too, so make sure you can connect a rigid bar to your towing eye!
http://cgi.ebay.co.u...=item5adc24d888
#5 pikey7
pikey7
  • 3,824 posts
Posted 20 October 2010 - 02:19 PM
why? afaik tow ropes are legal, must be a max length of 4.5M, and anything over 1.5m must be "clearly visible".
edit: only reference i can find to their "illegality" is from the highway code:
"In the event of a breakdown, be aware that towing a vehicle on a tow rope is potentially dangerous. You should consider professional recovery."
that doesn't make them illegal though...
Edited by pikey7, 20 October 2010 - 02:23 PM.
#6 Minii_Matt
Minii_Matt
  • 55 posts
Posted 20 October 2010 - 04:03 PM
Thanks for the help so far guys. Would a tow eye like this be a better option then? And would it be possible to attach the tow strap above to the bolt in the front mount of the subframe?
Thanks,
Matt
#7 ukcooper
ukcooper
  • 1,625 posts
Posted 20 October 2010 - 05:49 PM
I'd go with the mra type, got two fitted to the front of mini over a year now and no rust and looks good.
As for tow ropes i suppose it case of are you insured these days!!.
#8 samsfern
samsfern
  • 5,243 posts
Posted 20 October 2010 - 06:03 PM
i just use the towing eye on the front valence, but thats only really bolted on for trackdays on when i do breakdown, as mines debumpered and i dread to think how much damage it would do to the subframe if someone crashed into it.
I have been towed by the front eye with no problems.
I also have a hoop welded on the rear subrame, the hoop part of an exhaust clamp was used for this. I have had to be towed out backwards by it once when i put it in the kitty litter on a trackday.
#9 Gaffer
Gaffer
    Previously known as j519ldv. King of the spam costume!
  • 457 posts
  • Local Club: Crash Barrier Minis
Posted 20 October 2010 - 06:25 PM
apparently ropes are legal, i was with bungle but apparently not
#10 bunch1980
bunch1980
  • 1,192 posts
  • Local Club: nein
Posted 21 October 2010 - 06:18 AM
I have a towing eye from mini spare for front not yet fitted though, and im sure with these towing eyes you are only meant to use a tow rope and not a
fixed/rigid tow bar is this correct?
I only need it really for a very short distance as I have the AA to be recovered and not sure if they need a towing eye to recover or not.
Where i live is though a low under pass under our flat so AA wont be able to come through just wanted to be able to tow it to garage really!!
