Oil Leak From Diff End Cover
Posted 21 October 2010 - 03:14 PM
1990:
Oil Leak From The Diff End Cover, Is It A Diffucilt Job For Me To Do On My Drive? This Is A Video Of How Bad The Leak Is. http://www.youtube.c.../0/ZcSrjhPtdZA:
Cheers Tommo
Posted 21 October 2010 - 03:20 PM
May just be worth checking the bolts are done up to torque ( 18lbft ), if you find that they are not, or more likely one of them spins, then it'll need helcoiling.
As for changing, fairly easy, hack the car up on one side, crack the top ball joint and track rod end, withdraw the drive shaft and then undo the bolts... replace the gasket, diff seal and O ring around detent. stick it all back together..
If you get the angle of the car right, you won't need to drain the oil.
Posted 21 October 2010 - 03:21 PM
Posted 21 October 2010 - 03:25 PM
Cheers Tommo
Posted 21 October 2010 - 03:28 PM
I didnt even notice that, Ill have to get one on the weekendactually, just noticed you're missing the bottom bolt from the diff cover, that ain't gonna help matters.
Posted 21 October 2010 - 03:29 PM
Posted 21 October 2010 - 03:53 PM
Cheers Tommo
Posted 21 October 2010 - 04:06 PM
Posted 22 October 2010 - 03:47 PM
Posted 23 October 2010 - 03:11 PM
Posted 23 October 2010 - 04:14 PM
You could look at tapping a size up, but there isn't much spare metal. If the bolt grips at all you could swap it for a stud and glue it in, but that might make removing or shimming the cover a bit more fun.
