Alloy Fuel Tank Swap
14 replies to this topic
#1 skye
skye
  • 190 posts
Posted 21 October 2010 - 07:53 PM
I am wanting to swap the original MPI fuel tank for a nice alloy one that will take up my boot space but i don't know what i have to get in terms of a fuel pump or a regulator could somebody please help.
Edited by skye, 21 October 2010 - 07:54 PM.
#2 Bounce
Bounce
  • 2,197 posts
Posted 22 October 2010 - 04:31 PM
The place where your buying the fuel tank from should be able to advise you on this. If the tank is bespoke, try and use your existing pump.
#3 skye
skye
  • 190 posts
Posted 22 October 2010 - 04:47 PM
i'm afraid i have sold the original fuel pump with the tank but i have been given a bosch fuel pump! It has an operating pressure of 300 KPA and a flow rate of 130 L/Hr. Would this one work at all? does anyone know?
#4 skye
skye
  • 190 posts
Posted 22 October 2010 - 05:14 PM
bump does anyone know about the pump? i really need peoples input i would be very grateful.
#5 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 22 October 2010 - 05:52 PM
Get yourself one of these
http://www.fuelpumps...0-70psi-7-p.asp
Then two cotton reel exhaust hangars to mount it , mine is mounted on what used to be the rear seat metal support , however my gf has hers mounted under the rear subby so its a bit more user friendly
It runs my 1380 with webber 45 nicely , i did have a fuel pressure regulator but my engine builder said i didnt really need it for what i was doing , always best to check though
#6 skye
skye
  • 190 posts
Posted 22 October 2010 - 06:06 PM
thank-you for the input. Where could i ask to check though? I mean because it's electric fuel injection does that mean it is self regulated at the injectors? so therefore no need for a fuel pressure regulator? regards blue
#7 benno1275
benno1275
  • 391 posts
  • Local Club: bmc
Posted 22 October 2010 - 06:10 PM
i have a radtec fuel tank for sale if you are interested??
#8 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 22 October 2010 - 06:26 PM
take a look at some of these pumps
http://www.fuelpumps...-pumps-23-c.asp
your best asking " sprockett" or "Dan" for the pricise in's and out's and full spec for fuel injection pumps , my cooper was an SPI , but had the carb convertion carried out.
And with my MOD hat on , please use the classifieds for buying/selling in future , thanks
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 22 October 2010 - 07:19 PM
I don't know what the spec for the standard pump is, but I suspect the Facet 'cube' is not going to cut it for injection. They are designed for carb engines. Sprocket will know more.
The regulator is built into the fuel rail. You just need a filter at the tank end, I assume you are keeping the original.
Stroker, are you saying that the fuel pump is inside your car? That's very bad prectise and AFAIK is actually illegal and uninsurable. If the fuel line runs internally it must be one single length of solid material with no joints. You should fabricate a fire bulkhead box to cover it and seperate it from the cabin. If you've already done this, I apologise.
#10 skye
skye
  • 190 posts
Posted 22 October 2010 - 07:39 PM
thank-you very much for your input i will wait for sprockets input on the situation. I have purchased a new filter and a pre fuel pump free flowing filter >_<
#11 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 22 October 2010 - 07:49 PM
No worries dan,its all legal,safe and above board
#12 skye
skye
  • 190 posts
Posted 24 October 2010 - 12:48 PM
Has anyone heard from sprocket i sent him a pm on this matter of fuel pumping but no reply :thumbsup:
#13 skye
skye
  • 190 posts
Posted 24 October 2010 - 06:50 PM
bump. Has anyone heard from sprocket i did send him a pm about my predicament! regards skye
Edited by skye, 26 October 2010 - 02:23 PM.
#14 icklemini
icklemini
  • 2,982 posts
Posted 27 October 2010 - 07:40 AM
There is a fuel pressure regulator that.. regulates the pressure..
so if your replacement pump matches the original (3.5bar pressure).
Note that you will need a fuel return line back to the tank to return excess fuel..
Edited by icklemini, 27 October 2010 - 07:42 AM.
#15 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 27 October 2010 - 06:38 PM
That square brick is a pump for a carb.
You can use any sort of external injection pump, the popular one is the same one used for the Metro turbo. Plenty available on ebay, but it depends on how much you want to pay as to whether you get a genuine pump or 'something' else.
Plumb it up - tank>pump>filter>fuel rail. Keep the return as is, returning to the top of the tank somewhere, but not the tank breather. Use a fuel filter for injection. There are topics on the type of filter that can be fitted with barb fittings, nice and easy. Peugeot springs to mind.
Also be aware that if there is no swirl pot built into the tank, you will suffer fuel starvation with a low level in the tank and moderate cornering.
