What Cam To Get?
Posted 25 October 2010 - 09:07 AM
Thanks,
Matt
Posted 25 October 2010 - 09:17 AM
Edited by samsfern, 25 October 2010 - 09:19 AM.
Posted 25 October 2010 - 11:14 AM
Im looking at buying a reconditioned 1275 engine to replace my current 998. It will have a stage 1 kit and I want an uprated cam. The car will be used for everyday driving and I was thinking of getting either a Kent 266 or 276 cam. What cam would you recommend, and roughly what kind of power will I be looking at with my new engine?
Thanks,
Matt
If you can get hold of a 1275 engine that you know is reasonable, ie: working. It may be cheaper than buying a reconditioned one!! Lets face it you will have to take it apart anyway in order to fit the cam...Oh and dont forget to fit new cam followers, An absolute must if fitting a new cam. And the 276 is a good cam for your spec.
Edited by AndyMiniMad., 25 October 2010 - 11:15 AM.
Posted 25 October 2010 - 12:22 PM
Posted 25 October 2010 - 01:31 PM
Posted 25 October 2010 - 02:29 PM
If you're not going to get a 'stage 3' head then don't bother with a 276, you're better off with a SW5-07, not used a 266 although I did have one, if you're going to get a head and not bother doing anything with the bottom end, which is fine then I'd still recommend a tamer cam, as you don't want to be revving the nuts off a standard bottom end, they can still make good numbers and will make the engine a lot easier to drive. When I had a SW5-07 it was so tame I didn't even know it was there until I stripped the engine, I used to be able to get up most hills in 4th providing I wasn't doing something silly like 20mph, yet I've heard of quite a few 1380 engines with a semi decent head on + a SW5-07 make 100bhp + same torque. My engine made 58bhp at the wheels with a cooper S head, 1.5.1 rockers, cooper freeflow manifold onto a rc40 and hif44 on a mini spares inlet
I'm so glad you posted!
I am rebuilding a 1275 GT with a stage 1 kit... I have the entire thing in bits and was just about to order the SW5-07!
Posted 25 October 2010 - 04:20 PM
I may look at getting a modified head at a later date, when funds allow. The recon 1275 I have found is of a decent price and I prefer the idea of buying that rather than a used engine as I know that there should be nothing wrong with it. The camshaft will be fitted during the refurbishment, so I will not have to take the engine apart myself. I am currently leaning towards the 276 cam as it seems to offer more power and potential to use with modded head, whilst retaining driveability, by the sound of things.
If you fancy the 276 I have one for sale
http://www.theminifo...ct/15598/cat/18
Brand new with followers and a vernier.
Posted 25 October 2010 - 05:42 PM
If you do go for a 276, make sure the final drive ratio is 3.2 or lower or you might have trouble pulling away in traffic due to the high first gear.
I can't comment on SW cams as I've never worked with them. They don't publish timing figures and Kent do, so i like to use Kent cams as I've done now for 15 + years with excellent results.
Posted 26 October 2010 - 08:59 PM
Thanks for the replies.
Posted 26 October 2010 - 09:38 PM
However, I have heard good things about the quality of the piper range as well.
Posted 27 October 2010 - 02:34 AM
How does the sw5-07 compare to the Kent cams, as this looks ideal for my engine spec? Also, how would it run on a standard head, until I get the money for modifications?
I thought the spec and stuff I had read elsewhere looked excellent (and reasonably priced too)...
I e-mailed Swiftune and asked if it would be a good cam for my 1275 GT with Stage 1 kit. I guess I wouldn't have expected them to say 'no, buy something else' but for what it is worth here is their reply...
Hi,
Yes, the SW5 will improve performance. You will have better torque and an allround more efficient engine. The idle is like standard with very smmoth driving performance.
Regards
Arnold
Hope that helps...
