Lambda/oxygen Sensor Didn't Do Anything When Disconnected
1 reply to this topic
#1 bradderz
bradderz
  • 127 posts
  • Local Club: Stadishall Mini Club
Posted 27 October 2010 - 01:13 PM
1991 Mini Cooper 1.3 spi.
I was testing to see if the lambda sensor was working by disconnecting it, it did not do anything when unplugged, I tested it when it was warm and cold and both times didn't make a difference, could this broken and could this be causing my car to loose power when cold and also spluttering when cold?
#2 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 27 October 2010 - 03:32 PM
Hi, my (non Mini) experience with disconnecting the Lambda sensor is that if the problem goes away when disconnected, the sensor is bad. The ECU will adjust the mixture based on other sensors like MAP, TPS, coolant temp, etc. in the absence of the Lambda sensor and the engine should run perfectly. However, the Lambda sensor working properly will further refine the mixture settings for the Cat to do its job properly reducing emissions.
So, your sensor should be OK. Your problem is elsewhere.
Ivan
