Switch Panel Fitting
9 replies to this topic
#1 JoeCov
JoeCov
  • 63 posts
Posted 29 October 2010 - 04:33 PM
Hi
I've recently take off my dash rail coverings, so I'm back to the bare metal rails.....just the way I like it.
The switch panel is mounted on the 2 (brass?) brackets which bolt onto the the dash rail which used to make it sit flush onto the rail covering.
So now I want to remove the brackets and fit the switch panel flush onto the dash rail.
Problem is I can't see any way of holding it in place... What am I missing?
Do the heater and choke cables lock it into place?
Joe
#2 Ethel
  • 26,077 posts
Posted 29 October 2010 - 05:39 PM
Sits behind the rail & is held in by screws from the front.
Padded dashes use the same screw holes but the panel sits in front with little brackets coming off the cable fixings, held to the rail by nuts from the back
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 29 October 2010 - 07:12 PM
The hole in the rail of cars built with a padded dash is larger, the early switch panels won't fit. You need a switch panel from a late model van or pickup. These cover the larger hole.
#4 JoeCov
JoeCov
  • 63 posts
Posted 30 October 2010 - 06:54 AM
Hi Dan
Do any of the online spares sites have this type, it seems minispares don't?
Seen this....
http://cgi.ebay.co.u...=item43a2ac0e17
My current panel has 4 switchs, so this having 3 surely won't fit?
#5 analogue_radio
analogue_radio
  • 4,897 posts
Posted 30 October 2010 - 07:08 AM
I've done this.. just trying to find a photo (no luck) although I haven't fitted it in place yet as I'm still doing the bodywork etc..
I believe my panel was of a Pick-up, as Dan says its slightly larger.
#6 JoeCov
JoeCov
  • 63 posts
Posted 01 November 2010 - 02:56 PM
Thanks for confirming....
Can anyone point me to a supplier for the van panel please?
#7 tadleysimon
tadleysimon
  • 1,458 posts
  • Local Club: basingstoke mini club
Posted 01 November 2010 - 04:53 PM
i think m-machine do it, but there website is shocking, id give them a ring if i was u
#8 JoeCov
JoeCov
  • 63 posts
Posted 04 November 2010 - 10:10 AM
Thanks Simon....
Just gave them a call and placed an order, will take 1-2 weeks which is a bit of a shame.
But it will be woth the wait I hope!
#9 tadleysimon
tadleysimon
  • 1,458 posts
Posted 05 November 2010 - 10:17 AM
:thumbsup:
#10 1984mini25
1984mini25
  • 8,785 posts
Posted 05 November 2010 - 05:02 PM
Before i had to switch dashes i just tack welded a spare switch panel to sit flush with the dash rail.
Edited by 1984mini25, 05 November 2010 - 05:08 PM.
