Cone Or Pancake Filter?
6 replies to this topic
#1 The-Womble
The-Womble
  • 646 posts
Posted 31 October 2010 - 05:14 PM
Model: Sprite 1275 Carb
Year: 1993
I currently have a stock 1275 engine in my Sprite. I've bought a new Stage 2 Maniflow LCB and centre exit, and will be fitting it along with a water-heated inlet.
I'd like to change my air filter too on my HS4, from stock to a K&N Cone filter or Pancake filter, although I don't really know what the difference is in terms of efficiency/performance etc.
Which would be more suitable?
Thanks :D
Any non-standard parts that might be involved with the problem?
Maniflow exhaust system
Water-heated inlet manifold
#2 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 31 October 2010 - 05:29 PM
cone filer more area for air to flow into the engine
pan cake filer restricks the flow of air.
#3 Barman
Barman
  • 1,068 posts
Posted 31 October 2010 - 05:35 PM
Cone filter with Stub Stack?
#4 Cooperman
  • 23,320 posts
Posted 31 October 2010 - 05:42 PM
You need not bother with the water-heated manifold. It is usually better to keep the inlet charge as cool as possible. As for filters, the K & N cone with a stub-stack is the best. Another good 'tweek' is to put a small chamfer on the carb piston at its leading edge. A 30 degree x 3/16" chamfer, smoothed off with emory, does give slightly better throttle response and it's easy to do.
#5 Cerberus
Cerberus
  • 989 posts
+1,
vizard recommends stub stabs highly.
This is what I shall be replacing my old pipercross filter with.
#6 The-Womble
The-Womble
  • 646 posts
Posted 31 October 2010 - 05:57 PM
Ah yes, forgot to mention that. Got a stub stack to go on too. Looks like I'll try and get myself a cone filter then.
:D
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 31 October 2010 - 06:08 PM
You can instead simply file a nice smooth entry radius on the mouth of the carb - as large as possible. This will eliminate the vena contraca just as effectively as the 'stub' - and still keeps the inlet a good distance away from the front face of the filter. If the 'stub' has any length - it ends up far too close to the filter end cap. Pancake filter is useless - don't do it! The radius on the piston leading edge is also well worth doing - as are the various other mods รก la Vizard!
Edited by bmcecosse, 31 October 2010 - 06:08 PM.
