Garages Near Bath
Posted 01 November 2010 - 11:26 AM
Can anyone reccommend a mini friendly garage in the Bath / Bristol area?
It's an SPI engine, so where ever I take it needs to have the ability to deal with this.
Posted 01 November 2010 - 11:57 AM
Posted 01 November 2010 - 12:20 PM
What's wrong with it?
Ever since getting the car it has idled slightly fast, but that's not the main problem.
We hit a rather large bump in the M4 on Sat night and something on the underside hit the road. Following this the engine lost power. Pulled over and had a quick look under the car, but couldn't see anything obviously damaged so decided to start it back up and continue. It idles as normal, but would struggle under load and feel as though it was misfiring.
It seemed to slowly improve along the journey, but still wasn't quite right.
Since then I have cleaned and re-gapped the pugs as they were very black and on the return journey it seemed better although we didn't push it. The fuel consumption seemed quite high though.
I am confident with carb'd engines (specifically vw ones), but less so with injection.
My current though is that the jolt dislodged some dirt from the fuel tank that is now slowly working its way out of the fuel system. I haven't checked the filter yet or re-checked the plugs. I'm also going to take a good look at the underside when I've got time.
Basically just wanted someone who is knowlegable to take a quick look.
This is Ellie's boyfriend writing by the way,
Posted 01 November 2010 - 01:00 PM
The Injection Centre
The Stonehill Centre,
Units 2, 5 & 6 The Coachworks
BRISTOL
BS30 9DH
Tel: 0117 244 7899
Not Mini specialists, but have the right kit and a good knowledge, did help get it running just right and checked all over the engine, can give them a call.
I know of one Mini specialist near Bath, but they're not confident with SPI cars so wouldn't recommend.
Posted 01 November 2010 - 01:05 PM
I wonder if you've damaged one of the vac pipes that goes from the ECU to the back of the manifold. If one of these comes adrift it will run ultra rich and use tons of fuel.
Posted 01 November 2010 - 01:11 PM
I did have a code reader, but unfortunately I sold it!
Ok, I'll have a good check over those.
From the little I know, I know that if any sensor is damaged/disconected it runs on a default setting so I assume that could also lead to rich running.
Thanks for the help so far.
Posted 01 November 2010 - 01:12 PM
After we rebuilt mother's SPI Cooper we took it to be checked over by;
BRISTOL
BS30 9DH
Tel: 0117 244 7899
Ok, thanks. I'll give them a try if I can't get it sorted.
Posted 01 November 2010 - 04:23 PM
dave
