Ratchet Or Twist Choke ?
13 replies to this topic
#1 MrSporty
MrSporty
  • 75 posts
Posted 01 November 2010 - 05:43 PM
The twist choke in my '80 mini thou has started to drop back in of its own accord. I'm going to replace it but was wondering if:
a) The older twist to lock or newer ratchet type is the more reliable type.
b) Both of the ones im looking at are 31 inch but will the ratchet fit in the same dash panel hole as the twist type.
MrS
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 01 November 2010 - 06:52 PM
should do as later minis (like my 1990 cooper) came fitted with them
mine failed after about 10 years and i now have the early type fitted (not sure why)
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 01 November 2010 - 06:58 PM
No, the ratchet type cable fits through a larger, D shaped hole compared with the original smaller round one for the standard push-pull cable. You will need a new switch panel bracket and to either replace or modify the switch panel itself if you want to fit the ratchet cable.
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 01 November 2010 - 07:11 PM
are you sure Dan (hides for even doughting you)
when i swapped from ratchet to twist it was a straight swap
#5 1984mini25
1984mini25
  • 8,787 posts
Posted 01 November 2010 - 07:16 PM
The quality of new replacement choke cables is quite shocking; I got fed up of buying and fitting new ones each time. So in the end I resorted to using a wooden clothes peg to hold the choke out instead.
#6 1.3Cooper
1.3Cooper
  • 39 posts
Posted 01 November 2010 - 08:52 PM
.quote]
[/quote]
snap :thumbsup:
#7 finch661
finch661
  • 2,339 posts
Posted 02 November 2010 - 07:43 AM
haha same here, in both my mini and mg midget. the mg eats choke cables (only lasts about 3-4 weeks...now i use a peg...much more reliable :thumbsup:
#8 Pooky
Pooky
  • 5,691 posts
Posted 02 November 2010 - 08:43 AM
Mrs Pooky 'pimped' my peg as a Christmas present! Painted it red with racing stripes :thumbsup: added 12bhp on warm up!
#9 MattEvans
MattEvans
  • 74 posts
Posted 02 November 2010 - 09:02 AM
haha, glad its not just me having choke problems, i cut out 3 different width pieces of lead, I just bend them over in two behind the handle. Each for different types of weather! :thumbsup:
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 02 November 2010 - 10:36 AM
Dan's right.... maybe you had the wrong one to start with Bungle...
#11 Ethel
  • 26,141 posts
Posted 02 November 2010 - 10:46 AM
I've used a bowden cable, might've been pinched from a Sherpa, not sure it's been a while. Worked very well.
Couldn't resist a Google, there are plenty of cheap bowden cables on fleabay for radio controlled models, suppose you could have a go at doctoring one on to the end of a choke knob.
#12 jayare
jayare
  • 2,093 posts
Posted 02 November 2010 - 02:53 PM
Twist will fit into the ratchet hole but not the other way round,
JR
#13 1984mini25
1984mini25
  • 8,787 posts
Posted 02 November 2010 - 03:09 PM
haha same here, in both my mini and mg midget. the mg eats choke cables (only lasts about 3-4 weeks...now i use a peg...much more reliable :P
Ah but how sad is this. I have the choke set so when its fully out the choke is full open on the carb for first starting. Then I have the choke set with the thickness of the peg for the engine to tick over just above 1k with the choke out. Then finally without peg, choke full closed/off.
So it’s basically choke out, started, choke in with peg holding it out, once warmed up remove peg.
The added bonus is the peg is also used to stop the heater from rattling lol.
#14 MrSporty
MrSporty
  • 75 posts
Posted 02 November 2010 - 05:06 PM
Hehe , didn't get a chance to reply until tonight but thanks for all the info.
Funnily enough i am using a double peg setup at the moment :P Recently fitted a pieced together stage 1 and have yet to get it RR'd so im using the choke a bit more than usual to keep it happy.
Will let you know what i end up with.
MrS
