Fitting Bonnet Pins
9 replies to this topic
#1 mattsbmw
mattsbmw
  • 192 posts
Posted 01 November 2010 - 07:50 PM
Looking to fit some bonnet pins like on the mini in the top right corner of the forum.
Anyone got any advice on what i can secure them to under the bonnet and bet way of fitting them.
#2 luiji89
luiji89
  • 1,039 posts
Posted 01 November 2010 - 07:55 PM
i have seen some with welded metal plates in the corners...
suppose rivet could work
toby
#3 CaptainBland08
CaptainBland08
  • 675 posts
Posted 02 November 2010 - 01:38 PM
3 ways you can do it...
plates will be needed in all four corners in each case...
you would weld the plates on if your in a permanent mood... although i wouldnt advice this...
you can drill through the guttering round the edge and rivet the plates on...
or my personal favorite as i find rivets a tad shonky, is to drill the guttering and bolt the plate on with stainless fixings...
then simply drill the plate and bonnet for fitment of the pin... the pin shown in the picture is a generic design used by most companies... just go for a good quality stainless set to stop any nasty rust forming...
i havent got any pictures of the plates in situe but hopefully someone will oblige...
Chris
#4 hutch8282
hutch8282
  • 25 posts
Posted 02 November 2010 - 04:12 PM
I too am about to fit bonnet pins and looking through previous threads the best and most preferred way is welding in some plates. This is for a number of reasons:
Most permanent
Looks neat
They do not come loose
If bolting or riviting there are dissimilar metals touching which causes rust. The only way to get around this is by having some kind of insulation between the metals.
By using any of the above options you will have to paint anyway so why not do it write the first time.
Hope this helps make your mind up.
Cheers hutch
#5 mattsbmw
mattsbmw
  • 192 posts
Posted 02 November 2010 - 07:57 PM
Thanks for the replies so far :P
#6 leaky
leaky
  • 6,890 posts
Posted 03 November 2010 - 07:12 PM
As above really. Mine are riveted on. The metal used as pretty thin though so does flex and bend a bit. I'm gonna get some thicker stuff and then weld it on.
#7 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 03 November 2010 - 07:24 PM
Have a check of my project pages.
http://www.theminifo...x...5702&st=105
That's how I did mine.
Drop me a PM if you need more detail
Regards
Steve
#8 mattsbmw
mattsbmw
  • 192 posts
Posted 04 November 2010 - 08:33 PM
Big thanks to all who have replied, the pics and descriptions are excellent :thumbsup:
One more question, can i just fit the front pins and use the rear hinges still? if i do this is there enough clearance to get the bonnet over the pins?
#9 Pending
Pending
  • 524 posts
Posted 04 November 2010 - 08:41 PM
simple is no, you wouldn't get the bonnet over the pins
#10 retroracer1275
retroracer1275
  • 543 posts
Posted 04 November 2010 - 08:55 PM
ummm you could, just order these...
they are a brilliant bit of kit!
http://www.minimail....ed_products.jsp
(second one down :thumbsup: )
