Front Brakes Binding
Posted 02 November 2010 - 11:25 AM
I'm 99% complete on my rebuild where I've replaced almost everything
My front brakes are still binding despite rebuilding/replacing everything:
New wheel bearings
Replaced everything inside servo
New master cylinder (tandem type)
New brake pipes
Calipers refurbished by BiggRed (I finally gave up and sent them off after refurbing them myself).
New pads
Brakes are binding to the point where excessive force is needed to turn the discs. When pads are removed discs turn fine. I'm certain it isn't the calipers as I sent them away to be sorted- could anything else cause this?
Love to hear your thoughts!
Posted 02 November 2010 - 11:53 AM
From what your saying I think that the new pads are to thick and so they are hitting the new disks and binding. The same happened to me when I put new rotors and aftermarket pads on my ford falcon. SO im assuming thats the pads and disks are new. maybe go to ur local mini parts place and get them to measure the thickness of the pads. And compare to yours and other types/brands. I think you'd just need slightly thinner ones
Posted 02 November 2010 - 06:08 PM
ok heres my thoughts. what type of pads are you using. standard or some performance type ones?
I didn't think about this but yes, they are supposed to be performance pads. I've still got the old pads with plenty of meat on them so I'll give them a shot first. Thanks
Posted 03 November 2010 - 11:03 AM
see how ya go. What I did with mine then was find a level surface and some sand paper. then grabbed my pads and sanded a bit of the pad material off untill they fitted better. I know its dodgy but it worked lol.
Posted 03 November 2010 - 11:11 AM
We sanded off the layer of paint on the pad (back and sides), and that was just enough to give it enough clearance.
Posted 04 November 2010 - 07:59 AM
Posted 04 November 2010 - 08:23 AM
Putting old pads in didn't make much difference. I'm gonna check the pipes in case there's a kink somewhere restricting the fluid from moving back as easily.
Crack the bleed nipple open.
Push the pistons back in as far as they will go.
If they still won't fit properly, I'd file/sand/grind the pads down. Wouldn't do the first ones I'd had to do this to.
Wear a mask, watch the dust.
Edited by mikey72, 04 November 2010 - 08:30 AM.
