Grinding From Frount Nearside Wheel
13 replies to this topic
#1 robinlambert
robinlambert
  • 24 posts
Posted 02 November 2010 - 10:27 PM
1997 rover
sorry to post another squeaky front wheel topic!
so ive had this problem 3 times now, so im kindof lost to why it keeps coming back, get a loud grinding when traveling at steady speeds, more so turning to the left
replaced the wheel bearings and it went for a mouth, did the same with the balljionts, didn't hear it for another mouth, now its happening again,
im thinking maybe, distorted breaks, or cv jionts ? does that sound right
im going to take it all apart and put it back together tomorrow. im worried even if it goes, it will shortly come back
just a bit confussed to why it keeps going and then retearning with exactly the same sound after such a period later
#2 paul6266
paul6266
  • 482 posts
  • Local Club: Retro Classics
Posted 02 November 2010 - 10:55 PM
are u pack greasing the bearing?
#3 robinlambert
robinlambert
  • 24 posts
Posted 02 November 2010 - 11:11 PM
yep,
any idea what else could be the cause of premature wheel bearing failure?
got stranded 12inch minilights as wellcheers for the suggestion
#4 POWER5LAVE
POWER5LAVE
  • 517 posts
Posted 02 November 2010 - 11:14 PM
my discs used to grind as they were warped so that might well possible. you should be able to tell though by taking the wheel off and spinning the disc.
#5 robinlambert
robinlambert
  • 24 posts
Posted 02 November 2010 - 11:16 PM
could bad wheel alignment :/
it was only a mouth ago i last did them though surely something else must be buggerd
#6 robinlambert
robinlambert
  • 24 posts
Posted 02 November 2010 - 11:21 PM
last time i did that, they seemed a tinny bit tighter in one area. worth looking into
would i also have odd / excessive pad wear ?
also, safe to drive ? just annoying ?
#7 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 02 November 2010 - 11:25 PM
When did this the other week and i tightened the hub nut up and it went, but now its back...looking into it further tomorrow.
#8 robinlambert
robinlambert
  • 24 posts
Posted 02 November 2010 - 11:31 PM
that happend to me the second time round, came back after a few days, that's when i did the balljionts and it went, for a while longer,
ts worth looking to see if they are shot either way, and doing them while you have got eveything apart. couldn't believe the difference in handling after i did mine
#9 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 02 November 2010 - 11:43 PM
mine makes a new noise everyday, then it will go away and wont come back for a week. Its so anoyying because i cant fix it when its not there if you get me
#10 robinlambert
robinlambert
  • 24 posts
Posted 02 November 2010 - 11:49 PM
bloody stressful isnt it, esspcaily when you have a good look at everything that 'could' be the problem and it all moves how its meant to and looks how its meant to
does your noise happen more in wet weather ?
hope you find the cause soonish
#11 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 02 November 2010 - 11:58 PM
Mines like a graunching noise, not so much a grinding...its rotational and i notice it when im pulling up to a stop...i know i need to do my driveshaft gaitors and track rod ends anndddd other things tomorrow so hopefully it will solve it :P
#12 Cerberus
Cerberus
  • 989 posts
Posted 03 November 2010 - 10:24 AM
Does the noise vary with speed?
Does it go away if you lightly press the brakes?
I'd have thought it'd more likely be cv joints than discs, unless the discs are massively warped.
#13 MRA
MRA
  • 7,607 posts
Posted 03 November 2010 - 09:31 PM
I think that may be you guys are not following the recomended method for fitting wheel bearings, CV or brake disc........
Have you fitted it all together using a flat washer first, then fitting the split cone washer ? This method is laid out in the haynes manual in the supplement section.....
Hope fully this will help you all with your squeeky issues :thumbsup:
#14 robinlambert
robinlambert
  • 24 posts
Posted 04 November 2010 - 08:04 PM
proplem solved, i think. for the final time........ i hope.
my break pads had been nudged back a little and were grining on a rougth part of the disk.
