Windscreen Leaking
7 replies to this topic
#1 woodsy483
woodsy483
  • 182 posts
Posted 04 November 2010 - 12:09 PM
My windscreen was leaking when I drove the car home from buying it. Since then its been layed up while I'm refurbing it.
I've already bought a new winscreen seal but just noticed the one fitted has no fillet strip inserted
Before I order a fillet strip can anyone tell me if fitting the strip will solve the leak or will I be better of renewing the whole seal and fitting the fillet.
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 04 November 2010 - 12:11 PM
The fillet strip helps to lock the rubber down to the body (pushes the rubber onto the screen and bodywork) so it would help.
#3 ado15
ado15
  • 614 posts
Posted 04 November 2010 - 12:32 PM
Since you have the new seal, you might as well use it. The old one is likely to be hard with age.
As Big_Adam says, the seal is not complete until the locking strip is fitted.
#4 woodsy483
woodsy483
  • 182 posts
Posted 04 November 2010 - 12:45 PM
I was hoping this was the case, I think I'll order the fillet and give it a go before renewing the whole seal as I dont think the old one is in such bad shape
#5 mikey72
mikey72
  • 321 posts
Posted 04 November 2010 - 03:09 PM
Ours had actually shrunk slightly, and had a gap at the bottom of the seal, I filled that with silicone, and it's been dry since.
#6 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 04 November 2010 - 04:37 PM
Before you fit the fillet strip, you can inject some silicon between the rubber and the glass (not the body). Thats what I did. I found a really good silicone is made by permatex, and American company. It flows nicely which is the main advantage I guess, and it's made specifically for windscreens.
I think I have a spare tube, but click here to see the stufff you want. I am sure you get it through a British company or Ebay
Edited by mk=john, 04 November 2010 - 04:42 PM.
#7 woodsy483
woodsy483
  • 182 posts
Posted 04 November 2010 - 05:27 PM
Thanks for that John
I will give that ago before I fit the fillet, I have a tube of black Sikaflex knocking around somewhere in the garage that I got from work, it is what is used to seal in windscreens in on trains so that should do the trick
#8 mk=john
mk=john
  • 1,167 posts
Posted 04 November 2010 - 07:10 PM
Just make sure its flowable enough and has a thin spout which can fit under the rubber and on top of the glass as you drag it along. Just a thin bead will do. You probably find the screen will leak more in the bottom corners and scuttle as thats where it will collect.
