A Red Mini, No Freaking Way!
729 replies to this topic
#661 leaky
leaky
  • 6,890 posts
Posted 15 June 2015 - 08:47 PM
Right so busy focusing on the commer this keeps getting forgotten about. Did get her a few bits at Beaulieu though.
A good pair of headlight rings,
11143479_10154116874194848_3943906159178
Innocenti door pulls
11227515_10154116875634848_3751391342699
and the centre speedo housing.
603713_10154116874254848_188030604919242
As you can see I have started putting the housing together. Fitting that chrome thing was a nightmare haha. Just need to sort out so counter sunk bolts for it and I'll mount it in and sort out the wiring!
#662 rusty789
rusty789
  • 532 posts
Posted 21 June 2015 - 09:41 AM
Is this done yet?
#663 leaky
leaky
  • 6,890 posts
Posted 21 June 2015 - 10:35 PM
Is this done yet?
Yes!
#664 leaky
leaky
  • 6,890 posts
Na just kidding
#665 leaky
leaky
  • 6,890 posts
Posted 23 June 2015 - 05:14 PM
Right well been getting a few bits done.
Did a test fit of the speedo and gauges.
11012678_10154129026364848_6990378349600
Just as well I did as I found out it won't fit properly with the windscreen air vents as the later plastic ones are a different shape to mk1 ones. So I need some mk1 windscreen vents.
10473401_10154129026279848_8252446892287
Made a start wiring them all up, its always the most simple things you forget, turns out I didn't have any of the small screw fit bulbs for the speedo so I have ordered those, lights for the 2 small gauges sorted, one for the rev counter need needs wiring.
Horn is wired up and working,
Made a start on the headlights but they still need a little sorting,
Got stalks on and the wheel in
11057347_10154142158929848_3701226392193
Thanks for this guy for helping
11535798_10154142158989848_3569959011670
#666 leaky
leaky
  • 6,890 posts
Posted 23 June 2015 - 09:37 PM
Bit more of an update, huge thanks to Geoff for coming over tonight with his expert skills in miniing we got it running and a learned a thing or 2 as well!
Few bits I had got wrong when putting it together which we sorted, only issue is the fly wheel has come loose so at some point this week I'll wang the cover off and tighten it all up and check nothing been damaged. Got a shopping list for Brands Sunday so theres a few more odd bits I can crack on with. All in all a good evening, Nice to hear the engine running. Feeling a bit more positive about the while thing now.
#667 geoff-d
geoff-d
  • 468 posts
Posted 23 June 2015 - 10:47 PM
Wang away. I think you will be calling it something similar when you HAVE to take the woke cover bolts at the bottom out. Crack on
#668 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 23 June 2015 - 11:33 PM
Yeah good luck getting at the bottom bolts haha
#669 geoff-d
geoff-d
  • 468 posts
Posted 24 June 2015 - 06:42 AM
Jon will probably get you to do it Ross knight
#670 leaky
leaky
  • 6,890 posts
Posted 24 June 2015 - 08:09 PM
Shiny shiny came today
11207289_10154144964784848_1681238890307
Only one bolt left to do now.
10561786_10154145547839848_4378818489518
11059753_10154145547924848_7636622544987
might get the car in the air and do the last bolt one evening if not i'll wait until Saturday. Hope some more parts turn up this 2moz so I can get a few other bits done.
#671 RossKnight
RossKnight
  • 2,539 posts
Posted 24 June 2015 - 09:22 PM
good going to get all but one out, did you jack the engine up that side?
#672 leaky
leaky
  • 6,890 posts
Posted 25 June 2015 - 08:49 AM
Na, might have to do that on th last one. We shall see :)
Might order more DSN bling bling as well
#673 RossKnight
RossKnight
  • 2,539 posts
Posted 25 June 2015 - 09:31 AM
Do DSN not do a wok? haha
#674 geoff-d
geoff-d
  • 468 posts
Posted 25 June 2015 - 11:55 AM
Stop bolting bits on to it. & get that cover off. So we can see what's up with it you tart
#675 leaky
leaky
  • 6,890 posts
Posted 25 June 2015 - 04:36 PM
I like bling bling though :)
