Just a standard wiring loom, I need to know where abouts the fuse is for the indicators and the hazard lights. According to the haynes manual, its an inline fuse.
Does anyone know where the fuse is?? Ive looked everywhere I can think of but those fuses seem ok.
Also, does the windscreen washer pump run off the same fuse as indicators?
Cheers.
Where Is The Indicator/hazard Fuse?
GreenMini17
, Nov 09 2010 06:08 PM
1 reply to this topic
Posted 09 November 2010 - 06:08 PM
Posted 09 November 2010 - 06:14 PM
Cheers.
The inline fuse is tucked up under the scuttle panel usually above the carb area slightly to the right sometimes. And no the washers should be on a different fuse.
