Bulkhead/ Heater Matrix Seal Water Leak
8 replies to this topic
#1 asmith88
asmith88
  • 861 posts
Posted 11 November 2010 - 07:50 PM
i have a water leak coming in through the bulkhead, from where the heater matrix pipe comes through on the passenger side, i cant find it on minispares as im not sure what to call it, can anyone point me in the right direction?
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 11 November 2010 - 08:13 PM
Wait, so whats leaking? The matrix or do you just a leak from the pipe?
#3 asmith88
asmith88
  • 861 posts
Posted 11 November 2010 - 08:49 PM
the little rubber gromit in the bulkhead, which the heater matrix pipe comes through, is letting water through from the engine bay
#4 1984mini25
1984mini25
  • 8,785 posts
Posted 11 November 2010 - 08:52 PM
There isn’t a sealing grommet fitted as standard, just same foam/sponge stuff under the plate.
If you want to fit one though, you’d have to buy the ½” grommet like the one fitted on the drivers side and drill the hole out in the plate for it to fit.
#5 asmith88
asmith88
  • 861 posts
Posted 11 November 2010 - 09:06 PM
there is a seal already there, it looks fairly worn
#6 1984mini25
1984mini25
  • 8,785 posts
Posted 11 November 2010 - 09:08 PM
That will probably be what’s left of the foam stuff.
#7 Big_Adam
Big_Adam
  • 7,435 posts
Posted 11 November 2010 - 09:12 PM
I ne ... oh wait, Later cars DO have a rubber grommet thing for when pipes go through the bulkhead NOT the little plate. As I got one on my El Gordo (82 HL mini).
I know the part you mean, no idea what its called bar "a grommet".
#8 1984mini25
1984mini25
  • 8,785 posts
Posted 11 November 2010 - 09:18 PM
pre 88/89 no sealing grommet, just a hole in a plate through the bulkhead crossmember
88/89 onwards, 2 groments through bulkhead on passenger side.
#9 adder501
adder501
  • 33 posts
Posted 11 November 2010 - 09:52 PM
take a look at this:
http://www.minispare...ty=pb&pid=33082
It may be what your looking for if you have 1/2" heater hoses. I think these go through the plate.
Looks like later cars had grommets with part number of CLP6235 these are for cars with 5/8" heater hoses. I think these ones go through the bulkhead panel and are specially formed on an angle.
This part is not listed on minispares but give them a call and ask for availability they may have some in stock.
All detail is on the link above anyway.
All the best
Ad
