Dirt destroys bearings, the dirt on the remains of the old inner race is easily enough to kill that bearing inside 6 months. Everything inside the hub should be spotless. And make sure you clean all that grease off and out of the thread, if you torque that bearing up with that much grease in there you will crush it. No offence meant but that is some very sloppy work, you've got to take your suspension and brakes more seriously than this, they are important.
No offence taken this is the first time I have seen the inside of a hub. It failed it's warrant - the garage quoted me $500+ for parts and labour. So I googled it and armed with my Haynes manual I set about the task. Isn't that one of the things we love about minis. As for the brakes again first time I've seen inside a drum. Are they both the wrong way round - or just one. Should I replace with new? on both sides of the car at the same time?
Only one of the shoes will be wrong. ideally remove the shoes clean up all the metal parts inside there, the handbrake lever make sure its free to pivot,apply copper grease.
same with the square adjusting peg,apply copper grease
on the shoes you will notice one end the friction material doesn't go as far, that end goes at the top with shoe on the side closest to front of car. the other shoe fit with that end facing down rear of drum
shoes look dry and plenty of meat so just a light rough up with sandpaper is all ide do
Edited by lrostoke, 14 November 2010 - 07:22 AM.
