Battery Problems
Posted 13 November 2010 - 06:09 PM
problem is i charge it and my old battery used to fire teh car up no problems, cold, hot, snow, rain but this new one just turns over a few times and is dead. the minis damp in a morning so it needs a bit more power. kicks once but then theres not enough power left to start.
this is the new battery
■Startup Power: 265 Amps
■AH value: 35
■Reserve Capacity: 45
■Bench Charge: 3.5 Amps
■Weight (kg): 10.63
■Dimensions (LxDxH): 238x135x202mm
■Guarantee 3 Years
and the next one up is
■Startup Power: 300 Amps
■Ah Value: 42
■Reserve Capacity: 62
■Bench Charge: 4.2 Amps
■Weight (kg):10.63
■Guarantee: 3 Years
im crap at batterys and just took the standard one, as i have to keep jumping my car once in the morning and at night for when i go out as its cold do you think i should go and get myself the bigger one or is there an even better one than the one above.
im really stuck here guys because its getting annoying, i always used to say to my mates my mini loves the cold but now it doesnt.
dont mind getting the new battery although at £80 i got a halfords tarde card now and will save a bit and my brothers about to get a mini so i can put the current one it in that as its a project.
any helps guys?
Posted 13 November 2010 - 06:15 PM
Posted 13 November 2010 - 06:17 PM
when teh 38's full it will fire up the mini but only say from 11am till 3pm when its sunny, when its dark and cold when i need to go out theres no hope that it will start it
Posted 13 November 2010 - 06:29 PM
Posted 13 November 2010 - 06:45 PM
Have you tried bypassing the solenoid?
Posted 13 November 2010 - 06:46 PM
You want about 14.5 volts at the battery with the engine running, nothing switched on.
If your after an alternative battery one of the best is the Type 075
http://www.carbatter...60AH-I1002.html
I can't vouch for the above vendor though, but it shows spec and price.
Premium Car Battery
Voltage - 12V
Capacity - 60Ah
CCA(SAE) - 525A
Dimensions(mm)
242 x 175 x 175
3 years guarantee
Posted 13 November 2010 - 09:23 PM
Vauxhall battery, no. 93168488, 50A, 420CCA, £48.88, from any dealer.
drops in (just), never had any problem, and comes with a three year guarantee.
Posted 14 November 2010 - 12:41 AM
Edited by bmcecosse, 14 November 2010 - 12:42 AM.
Posted 15 November 2010 - 09:57 AM
Posted 15 November 2010 - 05:46 PM
Don't buy batteries from Halfords!
Posted 15 November 2010 - 10:06 PM
I've said it many times but here we go:
i am with you there
Posted 15 November 2010 - 11:37 PM
me 3 thas where mine came from... its a 075 and its fubar'd already...I've said it many times but here we go:
i am with you therenever again
Posted 16 November 2010 - 09:07 AM
Told you it was the battery cooking your ICE! the only ICE that should see spikes, is your snow tyres on the other type of ice.
Moral= high output alternator + high spec ICE with Halfords battery = Toast!!!!!!
Edited by customcart, 16 November 2010 - 09:09 AM.
Posted 16 November 2010 - 09:21 AM
my midget uses the halfords 038 battery, and i am onto my second one this year. My car has had the charging circuit checked, and earths cleaned. I find that the battery doesnt seem to have the juice to get it going!
Clean inside the battery terminals as well. They always corrode inside, and it first shows in the damp. I usually put a layer of bacofoil over the battery posts when I push them on, to help the connection.
