Boost And Reduction Pulley
Posted 19 November 2010 - 03:17 PM
Just wondering if anyone knows the boost of an Eaton 45 supercharger when it uses the standard pulley? I currently have the Vmaxscart kit fitted to my Mini, it's a 1275 with standard internals apart from 1.5 roller tip rockers and double valve springs. I'm just wondering if I could put on a reduction pulley or would it up the boost too much and cause me to have to upgrade the engine internals?
Thanks in advance,
Jon.
Posted 19 November 2010 - 05:22 PM
I can do a quick calc that will get a ballpark figure.
Posted 19 November 2010 - 05:37 PM
Hello,
Thanks in advance,
Jon.
Standard pulley 8-10psi, 15% pulley 12-14psi, 17% pulley upto 18 psi. However it all depends how well the head has been reworked. I have a 260bhp Bimmi (3 different rolling roads) and use a 17% pulley and only see max of 15.5psi. Bypass valve can play a key roll in boost with the Bimmi, I've adjusted mine correctly. You won't need a bypass valve on your classic however...
Our classic is running standard pulley and I'm seeing 8-10psi..
Edited by Grahamxx, 19 November 2010 - 05:38 PM.
Posted 20 November 2010 - 12:53 PM
Posted 20 November 2010 - 12:56 PM
Posted 21 November 2010 - 01:55 PM
The M45 isn't very efficient after 10psi or so anyway so there's probably not much to be gained .....
Interesting quote Phil, my Bimmi is running 15.5 psi with no problems, I know of cars running 18psi and aren't suffering any ill effects either as long as the ACT's (Air Charge Temps) are kept within limits...
Posted 21 November 2010 - 02:41 PM
So without using water injection etc you're a bit stuck. Obviously if it's blow through then it's a whole different ball game.
Posted 21 November 2010 - 03:21 PM
they will be flowing a different amount, and therefore be running in a different part of the compressor map and be at a different efficiency, eitherway they will be right off the top of the map and chucking out 100degC+
http://www.eaton.com...t/ct_128483.gif
Posted 21 November 2010 - 04:35 PM
You can't get away from the fact that at 15psi the efficiency is well below 60%.
