Determine Exact Year Of Car
23 replies to this topic
#16 charie t
charie t
  • 3,153 posts
Posted 20 November 2010 - 03:47 PM
late 70s/early 80s, mk3
Theres no holes in the top dash rail
hole in the inner wing for air scoop
Raised area under the wiper motor
#17 bardan
bardan
  • 21 posts
Posted 20 November 2010 - 05:26 PM
Yes, heater hoses are 2 inches apart going into the heater. yes to holes in inner wing for air. Yes to raised area (approx 1/4 inch) under wiper motor. Only holes in top of dash are defrost and ashtray.
As far as handling, this car out handles my MGB.
Edited by bardan, 20 November 2010 - 05:30 PM.
#18 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 20 November 2010 - 08:32 PM
I should certainy hope so! Mini : 4 wheel independant suspension by double wishbones/trailing arms with self damped springs all round. As in a sportscar. MGB : Kingpins, lever arm dampers, live axle on cart springs, essentially a stagecoach!
#19 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,154 posts
  • Name: Sean
Posted 20 November 2010 - 09:44 PM
Obviously a non MGOC member!!
#20 bardan
bardan
  • 21 posts
Posted 20 November 2010 - 10:12 PM
Just a quick note, late 70's, would be Mk4. Mk3's still had the round tunnel, Mk4 1976 onwards had the flat topped tunnel.
Just when I thought the car was from the 80s, I pulled the carpet and see a round tunnel. This car may be a gathering of quite a few different pieces. I checked all the windows and except the windscreen they have a date code of 9-82.
I guess I'll just order body parts for a MK3 and hope it's right
#21 1984mini25
1984mini25
  • 8,843 posts
Posted 20 November 2010 - 10:16 PM
check that the steering rack has been swapped for a LHD one and not just turned upside down because it will wear out quickly and handle poorly if mounted upside-down.
It would, indeed, handle poorly.... it would go left when you turn the steering wheel right!!
Would be a great theft/security device though, can’t see it getting far if the thief can’t work out the steering lol
#22 Shifty
Shifty
  • 13,154 posts
  • Name: Sean
Posted 20 November 2010 - 10:19 PM
Also by doing a reg search on your reg number your car comes back as a mini clubman!!
(not an Austin Cooper!!)
#23 charie t
charie t
  • 3,153 posts
Posted 20 November 2010 - 10:57 PM
oops no idea why i put 3 :( well spotted
#24 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 20 November 2010 - 11:10 PM
Wrong....
The change of tunnel came in with the rod change box, circa 1973.
