thanks scott
Wheel Spacers
Posted 21 November 2010 - 10:11 PM
thanks scott
Posted 21 November 2010 - 10:45 PM
The main thing that wheel spacers will mess with, is the handling. It'll mess with the steering geometry. How this'll affect the handling, i can't say i know, but it'll certainly have an effect.
Posted 21 November 2010 - 10:54 PM
Posted 21 November 2010 - 10:55 PM
Posted 21 November 2010 - 11:08 PM
Not too shabby! Just lose the flag
Posted 21 November 2010 - 11:28 PM
so can anybody help me? my wife is gunna get them for me for xmas and some spacers if i can tell her what to get
Posted 22 November 2010 - 12:14 AM
cheers
dean
p.s hope this helps lol
Posted 22 November 2010 - 01:01 AM
Posted 22 November 2010 - 01:14 AM
Posted 22 November 2010 - 11:46 AM
If you have the correct wheels, of whatever width, you should not need spacers except, possibly, thin ones on the rear to obtain tyre clearance from the radius arms (maybe 6 mm max.).
Remember, the max tyre width on a 12" wheel is a 165 and the max wheel width for a 165 is 6". Wider than that and you are in breach of 'Construction & Use regs'.
You can buy 6" wide 12" diameter wheels which don't require a spacer and which will sit under the Group 2 arches.
Posted 22 November 2010 - 02:06 PM
dean
Posted 22 November 2010 - 03:37 PM
It's worth noting that spacers that wide move the "strain point" on the bearings outwards so that your outer bearing takes a lot more of the steering force/weight of the car, hence premature or catastrophic failure.
The hub and bearings are designed to be used with wheels using a small offset. This means the wheel can be narrow or wide, but the wheel offest puts the "strain point" somewhere in between the two bearings so sharing the load.
Even with this set-up wide 13" wheels can reduce the life of the bearings, so wide spacers with larger wheels is a definate no-no!
Steve.
Posted 22 November 2010 - 03:52 PM
Posted 22 November 2010 - 07:07 PM
Posted 23 November 2010 - 08:35 AM
