Does Anyone Know The Width Of..
15 replies to this topic
#1 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 23 November 2010 - 08:48 PM
does anyone have or know the width of the complete rear subframe, from the very outter edge of the drum brake (with built in spacer) to the outter edge of the opposite drum brake? i have a cunning plan :D
#2 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 23 November 2010 - 08:52 PM
i have a cunning plan :o
Trying to fit a fully built subframe into the boot of a car by any chance? (not in the boot of a mini obviously :D )
#3 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 23 November 2010 - 08:59 PM
nope! although i have done this already, got a complete built up rear subby including wheels in the back of my clubman estate, the back door were open slightly and i had to cling onto a wheel to stop it falling out the back, but then again i was only taking it 200yards lol
im in need of the width as im looking into making my estate rear wheel drive using a robin reliant rear axle, and need to know the width of a mini subframe fom hub to hub so i can compare the reliant axle with the width of the mini shell, to see if it was viable
#4 tulka
tulka
    Just On Tickover
  • 6 posts
  • Local Club: m7c
Posted 24 November 2010 - 11:11 AM
Rear track of a 12" mini is 1205mm, ET of a steel wheel is 35mm.
Answer to your question is about 1275mm?
Tulka
Edited by tulka, 24 November 2010 - 11:16 AM.
#5 charie t
charie t
  • 3,153 posts
Posted 24 November 2010 - 12:51 PM
According to the hand book
Track: Front - 47 7/16" (1.205m)
Rear - 45 7/8" (1.165m)
#6 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 24 November 2010 - 05:15 PM
hmmmm interesting! as the reliant rear axle is 50 and 3/4" from one side to the next.... so only 5" differnce! so it would be viable.... now to hunt for parts :P
#7 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 24 November 2010 - 05:42 PM
I know I'm probably going to regret this, but I have to ask..... "Why Exactly??"
#8 Brams96
Brams96
  • 2,308 posts
Posted 24 November 2010 - 07:24 PM
Try this LINK
There is also this one which you'll probably find the most help.
#9 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 24 November 2010 - 07:40 PM
there are motorbikes out there that use a drivehaft instead of a chain to turn the back wheel, you could mount said bike engine up front, run the prop shaft down the exhaust tunnel to the reliant rear axle making it rear wheel drive, the shell wouldnt be heavily modified so could always be returned to standard...
plus it aint been done before, its different than the usual r1/z cars type build, honda/vauxhall set up, and you would get v.good miles per gallon!
anyone know what motorbikes run shaft drive?
#10 minidream94
minidream94
  • 1,233 posts
Posted 25 November 2010 - 09:36 PM
you can use a normal bike engine as there are companies that make sprockets that mount to the output shaft and enables you to run a shaft to the rear axles, hence why kitcars run bike engines to the rear wheels :thumbsup:
#11 Brams96
Brams96
  • 2,308 posts
Posted 27 November 2010 - 07:05 AM
BMW produce shaft drive bikes one of them being, funnily enough, the K-series which people use the cylinder head on the A-series block.
Others include the Honda CX500 & VT500, Yamaha XJ650, 750 & 900, and Kawasaki GT550 & GT750 so plenty to choose from.
#12 midridge2
midridge2
  • 1,794 posts
Posted 27 November 2010 - 08:13 AM
do they have reverse gear?
#13 Brams96
Brams96
  • 2,308 posts
Posted 27 November 2010 - 09:37 AM
A motor bike with reverse?? Are you being serious?
#14 midridge2
midridge2
  • 1,794 posts
Posted 27 November 2010 - 11:24 AM
Yes, i know some harleys and big hondas have/had reverse.
fitting a motorbike engine with no reverse makes hard work having to get out and push it backwards.
#15 Timtom
Timtom
  • 2,143 posts
Posted 27 November 2010 - 12:33 PM
Some of the conversions come with a motor for reverse. (zcars etc) but its an optional extra.
