Hole In Bulkhead For Stereo
6 replies to this topic
#1 karlos_junior
karlos_junior
  • 176 posts
Posted 23 November 2010 - 11:22 PM
riley elf
I wish to "hide" me stereo behing a small glove box. do to this I need to make a hole for the back of the stereo to stick out of. (180 x 50 mm)
I have the hole where the old speedo use to be (Was thinking I would blank off the old speedo hole when I do it.) I need stereo to the side of this. Will removing more out of the bulkhead cause any problems??
#2 Sam Walters
Sam Walters
  • 2,765 posts
Posted 23 November 2010 - 11:39 PM
So you need the front of the head unit within the glove box? I think i have a solution if thats the case
#3 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,144 posts
  • Name: Sean
Posted 23 November 2010 - 11:42 PM
Theres probably better ways to hide the stereo.
I've seen people use a remote controlled head unit and then fit it under the rear seats. They then just use the remote to control it.
#4 karlos_junior
karlos_junior
  • 176 posts
Posted 24 November 2010 - 01:03 AM
and that solution is>??? that is perfectly what I want. I had a look for SD card stereos but still to long.
Edited by karlos_junior, 24 November 2010 - 01:38 AM.
#5 karlos_junior
karlos_junior
  • 176 posts
Posted 24 November 2010 - 04:55 AM
had a mate that did that and it was always fun watching him struggle with adjusting the bass etc!! drove him batty....
Anyway I dont mind putting a hole in the back. I just wish to know if I would be doing something to affect the strength of the car
#6 danrock101
danrock101
  • 2,478 posts
Posted 24 November 2010 - 04:59 AM
or just get an amp and have a aux wire under the drivers seat and plug your phone into it to play songs off that, I downloaded a internet radio app on my phone so I have every radio station going lol
#7 partsguy1
partsguy1
  • 163 posts
Posted 24 November 2010 - 06:38 PM
A standard DIN sized head unit should fit, it just needs to sit at a slight angle. I made a MDF plate and stuffed it in ....... a little tight, but it fit. I like having it hidden.
Attached File  Stereo_in_glovebox.JPG   845.96K   11 downloads
EDIT: this is in a MKI L/H drive, installed in left side glovebox, so no fresh air hose behind it.
Edited by partsguy1, 24 November 2010 - 06:43 PM.
