Whats The Resting Position Of The Clutch Pedal, Same Height As The Brake Pedal Or Above Or Below?
2 replies to this topic
#1 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 26 November 2010 - 05:54 PM
My clutch pedal is sitting just a small fraction above the brake pedal height, is this correct or should it be sitting alot lower?
Vid of the back of the pedal hitting the bodywork
Is the back meant to rest against the bodywork when fully released? I can't remember what the standard setup is?
Edited by Kam, 26 November 2010 - 05:55 PM.
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 26 November 2010 - 07:10 PM
No the brake pedal should be higher by a fair bit, and I don't think your clutch pedal looks healthy there. The circlip may have come out of place inside the master, you may be only one or two de-clutches away from filling the footwell with brake fluid. Knowing you Kam, that could result in a nervous breakdown. I may buy shares in Autoglym in advance of your cylinder bursting.
#3 Kam
Kam
  • 4,140 posts
Posted 26 November 2010 - 07:26 PM
Its ok Dan I'm more chilled (no current weather pun intended) nowdays :-
Where is the standard pedal meant to be sitting when relaxed? Half way, three quarter? I've got an aftermarket clutch master which is adjustable underneath (running honda not a-series now) and its a 14mm so alot less than standard mini 16mm or whatever it is
The clevis pin is adjustable on the thread so am I right in thinking if I shorten it it will 'lower' the pedal?
