Mini Cooper Spi Temp Gauge Not Working?
Posted 27 November 2010 - 09:48 AM
Posted 27 November 2010 - 03:59 PM
Could also be the coolant needs replacing, aftter flushing the system.
I'd try these first. Sensor is more awkward to replace
Posted 28 November 2010 - 12:19 AM
Have you checked the thermostat ?????
Hi its had new coolant recently, what do i need to check on the thermosatat?
Posted 28 November 2010 - 12:50 AM
i dont see how the coolant need changing or the thermostat can make a gauge not work! if it was overheating then check them, but not for a gauge not working!
Posted 28 November 2010 - 12:54 AM
Hi does anyone no why my temp gauge isnt working, some say that its a sersor however i dont no much bout engines? Does anyone no.
If the gauge is not reading at all it is most likely the temperature transmitter (sensor):
http://www.mra-minis...r185-gtr307.htm
On your car, this screws into the cylinder head. Check to see that the wiring has not become loose or detached; otherwise the part is not expensive and quite easy to replace.
Posted 28 November 2010 - 09:54 AM
Posted 28 November 2010 - 11:57 PM
Posted 29 November 2010 - 12:32 AM
Posted 30 November 2010 - 10:27 PM
have you checked the wiring first? its a pig of a job getting at the sensor! it doesnt just screw into the head, its under the manifold!
I will do thanks mate
Posted 01 December 2010 - 09:28 AM
Just hold up here a minute, before you start diving in. So you've got a car that's not coming up to temperature (or the temperature gauge is broken which is possible but unlikely) at the same time as this.
Hi i have a 94 mini cooper and was wondering what this prob is i have little slatters of oil coming at the back, i have been told it mite be valve rubbers? what another head that i have work if it has a good valve rubbers?
Oh and also
Hi i was driving today and my car just started reving loads i was wondering if anyone knew what this could be my car is a 94 mini cooper. I no there is a sensor or somthing under the pedal is it that? does anyone no what parts i need?
Now these may be three seperate issues (But my guess is they may all be related).
It seems to me you need to get this car on a diagnostics test and find out what's working and what's not. Your problems may be linked to one or more sensors.
Some of the symptoms you are seeing seem to be related to the car not coming up to temperature. If this is true the temperature gauge will obviously read low, the ECU will constantly run in start up mode giving a high idle speed and run rich. You can only prove this by getting it on a proper engine diagnostic test.
If you decide to do this Check with whoever that they have the right kit to test a Rover Mini SPI. The system was different to modern engine management systems and not everyone still has the kit to check it out.
Posted 27 April 2011 - 04:39 PM
And .... what to look for in the wiring? what color is it and where does it go to or come from?have you checked the wiring first? its a pig of a job getting at the sensor! it doesnt just screw into the head, its under the manifold!
Mine works intermitently, it will work fine and just drop while driving
Thanks, Peter in the USA
Posted 28 April 2011 - 07:36 AM
(Finger trouble see next post)
Edited by Nu2mini, 28 April 2011 - 08:00 AM.
Posted 28 April 2011 - 07:52 AM
The first thing I would say is to get the car hooked up to the correct diagnostic tool. I appreciate this may not be too easy in the States but is the best starting place if you can. It will save you time and possibly money. Then post the readings here. These problems are best diagnosed systematically, otherwise we may just be stabbing in the dark.
Are there any other things happening ??
How frequently does the temperature gauge go intermitent. ?
Is the electric fan kicking in and does this coincide with the change in the temperatiure gauge ??
What revs does the car idle at
1) When Cold
2) When up to temperature
3) When the temperature gauge goes intermittent
Here's a link to a very detailed technical explaination of how everything works. It may be useful, but use it wisely. Don't just jump to conclusions without some evidence.
SPI Coolant temperature Sensor or is it ????
Posted 28 April 2011 - 11:23 AM
Peter,
1) When Cold
Thanks, a very informative post. Fooled with the wires yesterday to make sure that there were no faulty grounds, this morning it warmed up well and drove to work with the readings in the normal, (just below the black line!) so I will watch it for now, if it starts up again, I'll tackle the thermostat.
