Lhd To Rhd Conversion
6 replies to this topic
#1 jinx6187
jinx6187
  • 54 posts
  • Local Club: CCKT, MSOC
Posted 29 November 2010 - 07:30 PM
~~~~~Please delete this text before posting the topic~~~~~~
Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
[b]Model:[Austin Mayfair Soirt]
[b]Year:[1985]
I have a LHD that I got here in Germany and really want a RHD. Has anyone ever done the conversion? If so what all is needed and is it really worth converting or should I just sell it and get an orginal RHD?
#2 MRA
MRA
  • 7,607 posts
Posted 29 November 2010 - 07:36 PM
subframe out to change rack is possibly the hardest job..... plus electrical switches etc..
#3 1995 MK2 IOM
1995 MK2 IOM
  • 810 posts
  • Local Club: NO CLUB HERE.... YET
Posted 29 November 2010 - 11:16 PM
Mine was a German left hand Balmoral in 1995, its now a Right handed BRITISH Balmoral :) I dont know when it was done. but it doesn't seem to give me any problems etc... although it is my first mini... so I dont have anything to compare to!
just wish I didn't have a hole in my passenger side carpet... (I like the leather trim around the carpet - by the way... is that a factory fitted option? or is it aftermarket to have leather trim around the carpets?)
Over and out...
J
#4 Cooperman
  • 23,309 posts
Posted 30 November 2010 - 12:06 AM
I converted my Innocenti from RHD - it had been converted from its original LHD by an earlier owner - back to LHD and the conversion was really simple.
You need a new rack, move the brake and clutch cylinders to the other side using new brake lines, a RHD throttle pedal (the rest of the pedal box is interchangeable). The wiring loom to the steering column is just re-routed to the other side without any mods.
Just drop the aft end of the front sub-frame by about 3" to get the old rack out not forgetting to undo the front dampers in order to do this.
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 30 November 2010 - 12:18 AM
While the pedal box can be moved as a complete unit, for this age of car there are different LHD and RHD brake and clutch pedals. LHD pedals in a RHD car put your feet off to the left, your clutch foot ends up under the heater.
#6 Cooperman
  • 23,309 posts
Posted 30 November 2010 - 12:41 AM
I'm sure you are right. The Inno was just a straight swap except for needing a LHD throttle pedal. In fact, I could have heated up and bent the RHD pedal but I listened to someone else - should've just measured it all.
Personally I would not change it, just leave it LHD. But then, I like LHD cars as they are so much nicer to change gear in if you are right handed.,
#7 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 30 November 2010 - 10:28 AM
im doing the exact same as you except my mini is from holland :) im going the full way and switching the wiper motor and the wiring loom except thats because the loom is ******* lol but its pretty simple so far :)
