Antifreeze
6 replies to this topic
#1 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 02 December 2010 - 11:15 AM
Hiya how much does a mini hold gonna change antifreeze as its all water at mo and don't fancy cracking engine block thanks Danny
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 02 December 2010 - 11:19 AM
when you get your antifreeze, get a little tester too...
eg..
http://www.halfords....tegoryId_229902
#3 Ethel
  • 25,971 posts
Posted 02 December 2010 - 11:57 AM
A couple of litres should do. The cooling system holds about 3 1/2L & a third to a half mix is best.
It's forecast minus silly for the beginning of next week 'n those A series blocks are getting rarer, if you don't know when yours was last changed get it done - it doesn't last forever.
#4 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 02 December 2010 - 12:19 PM
Ya gonna change it tomorrow so a five litres is more that enough? ?
#5 Ethel
  • 25,971 posts
Posted 02 December 2010 - 12:25 PM
Too much, antifreeze has a shelf life. Buy a couple of litres (not ready mix); flush the system, pour about 3/4 in then top up with water - don't forget to refit the hoses :(. You can then fill the bottle with water 'n keep it for top ups.
Since antifreeze is also a corrosion inhibitor, your cast iron A Series should be well dosed all year round. It's principally to keep the rust at bay that it needs changing, the side of the bottle will tell you when.
#6 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 02 December 2010 - 12:31 PM
So 2.5 litres is enough put 2 litres in top rest up and keep the 500 ml top up the bottle and keep in car for top ups
#7 crazycoleman118
crazycoleman118
  • 836 posts
Posted 02 December 2010 - 02:32 PM
should be good enough!.... a 50 50 ratio is good for something like minus 30 i believe so thats plenty, however too much is just as bad as too little so bare that in mind :(
