Posted 16 December 2005 - 03:59 PM
You say they pump up OK but 2-3 seconds later they're soft again. Pay close attention to how the pedal behaves when you try that pumping.
If you pump 2-3 time (quickly) and you get a high pedal but it feels springy, make sure your calipers are right-side-up and that you have properly bled all the air out. You've put new brakes on the front... did you bleed ALL 4 wheels? If not, bleed all four wheels starting with the one furthest away from the master cylinder and work sequentially to the one closest to it.
If you pump the pedal 2-3 times and you get a firm, high pedal that isn't springy, readjust your rear brakes. No joke. You'd be surprised how much extra pedal travel you will have if the rear brakes are not properly adjusted. If your pedal is firm and high after pumping 2-3 times it's an indication that the first pump or two moved the shoes against the drums and the third is holding them in place. Without air in the system the pedal will be hard.
