Shift Warning Beep
6 replies to this topic
#1 CaptainBland08
CaptainBland08
  • 675 posts
Posted 04 December 2010 - 12:52 AM
hey,
ive tried searching for this but results are very limited and explain almost nothing relevant...
what i want to do is make a shift warning beep on my mini... the same as you get from an impreza sti... sounds kinda like an alarm clock beep.
how exactly would i go about making one? would it be better to buy one? how does it come on at certain rpm?
obviously it would be wired in a similar way to a shift light... but i dont know how they work...
any info would be great...
Chris
#2 Ethel
  • 25,971 posts
Posted 04 December 2010 - 01:33 AM
You'd need some sort of pulse counting device hooked up to the ignition, shouldn't be hard using some sort of PIC.
Google, Picaxe or Arduino
#3 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 04 December 2010 - 02:00 AM
How about buying a cheap shift light off ebay, then wiring a cheap buzzer into the light output of that?
#4 Wil_h
Wil_h
  • 3,244 posts
Posted 04 December 2010 - 08:11 AM
As above, use a shift light and change the output. But I don't know if the output would drive a buzzer.
#5 bcjames
bcjames
  • 2,728 posts
Posted 04 December 2010 - 08:55 AM
If not, could it provide signal to a relay to drive a buzzer?
#6 CaptainBland08
CaptainBland08
  • 675 posts
Posted 04 December 2010 - 06:01 PM
cheers for the replies... might butcher and old alarm clock and buy a cheapo shift light...
Chris
#7 Pyr0
Pyr0
    Just On Tickover
  • 8 posts
Posted 07 December 2010 - 11:47 AM
If it wouldnt power the buzzer you could use the light and just before you connect to the light use a simple contactor and run the buzzer dirrectly off the battery witha inline fuse, that might work but im not 100% positive.
