Handbrake Warning Light
11 replies to this topic
#1 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,725 posts
  • Name: Chris
  • Local Club: None
Posted 04 December 2010 - 08:34 PM
im in the middle of refurbing my 1979 and as part of that im making a custom dash, so i was going through CBS online looking at there warning lights and things and it dawned on me that i didnt no wether my mini would have a warning light to say that the hand brakes on or not,
so does it have one?
if not how easy would it be to wire one up?
cheers guys
YetI
#2 Ethel
  • 25,943 posts
Posted 04 December 2010 - 08:40 PM
It doesn't, hence the "special" brake test switch.
Metros use near enough the same lever with a switch fitted, you could adapt the brake test circuit.
#3 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
i cant see it being too hard to do, a push to break switch below the handbrake and a lil bit of wire. someone'l come along with the details shortly i'd say
#4 yeti21586
yeti21586
  • 3,725 posts
  • Name: Chris
  • Local Club: None
Posted 04 December 2010 - 08:45 PM
i was thinking a courtesy light switch mounted under the hand brake
#5 yeti21586
yeti21586
  • 3,725 posts
  • Name: Chris
  • Local Club: None
Posted 04 December 2010 - 08:47 PM
didnt think that had anything todo with the hand brake thought that was just to warn you when you had no brake fluid
YetI
#6 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
that'd work, take a look at the wiring diagram for the courtesy light in the haynes and pretty much just copy it for the handbrake light
#7 yeti21586
yeti21586
  • 3,725 posts
  • Name: Chris
  • Local Club: None
Posted 04 December 2010 - 08:52 PM
lubbly jubbly nice a simples
fankoooo wery much
YetI
#8 Ethel
  • 25,943 posts
Posted 04 December 2010 - 09:00 PM
YetI
It doesn't, but it does on a Metro (etc) the handbrake switch does the same job.
#9 ibrooks
ibrooks
  • 1,017 posts
Posted 05 December 2010 - 09:35 PM
There are three warning lights on a Metro. Only one is to tell you that the handbrake is on. After a certain date a low fluid warning light is a requirement and part of it's required operation is that one person has to be able to test the bulb. In most modern cars it has a slave onto the handbrake warning so that whenever you operate the handbrake it tests the low fluid level warning bulb. The Mini didn't have a switch on the handbrake to test the bulb so you get the switch on the dashboard that "doesn't do anything".
Iain
#10 yeti21586
yeti21586
  • 3,725 posts
  • Name: Chris
  • Local Club: None
Posted 05 December 2010 - 09:42 PM
it does do something it lights up
#11 ibrooks
ibrooks
  • 1,017 posts
Posted 05 December 2010 - 10:49 PM
Hence the quotes - it's common to get the question from new Mini owners asking what the switch that doesn't do anything is for.
It's more accurate to say it's a warning light for low brake fluid (and on some Minis a brake pressure imbalance which might indicate a leak). Pressing it tests the bulb.
Iain
#12 rwerry
rwerry
  • 386 posts
Posted 06 December 2010 - 07:03 AM
My Aussie 1978 LS1275 has a handbrake warning light as standard. The switch is, indeed, very similar to a courtesy light switch and is mounted horizontally and parallel to the RH cable on a small bracket fixed to the rear handbrake mounting bolt. The back of the cable mount pushes against it when the lever is released.
The warning light itself is labelled Park Brake and is mounted on the upper dash rail padding immediately above the RH indicator warning light (3 clock Clubby dash) and is matched by a Brake Fail warning light directly above the LH indicator warning light. In both cases the labelling is incorporated in the warning light lens which is about 1cm square.
UK owners may be amused to learn that lack of a handbrake warning light is one of the main reasons why late model English Minis fail to meet Australian design rules!
