Hi all, i am putting together a set 1.25 twin carbs and wondering
how many springs to put on 2 or 3, is there springs for the accelator return
and is there a spring for the choke
Thanks in advance!!!
How Many Springs For Twin Carbs
087dave
, Dec 05 2010 08:50 PM
8 replies to this topic
Posted 05 December 2010 - 08:50 PM
Posted 05 December 2010 - 08:53 PM
I seem to remember that my old twins had three springs on.
Posted 05 December 2010 - 09:04 PM
not sure about choke, but there should be 3 throttle return springs.
Posted 05 December 2010 - 09:26 PM
I've seen set ups with various numbers of springs, but three is the norm. It all depends on how much feel you want in the peddle.
Posted 05 December 2010 - 11:03 PM
The choke return spring is integral with each carb. Each throttle has a return spring and there is an additional one for the cable. I never bother with this third one as the two throttle ones provide adequate control of the throttles and make the pedal the right weight.
Posted 06 December 2010 - 01:03 AM
^^^^^Agreed^^^^^^^
The only problem that I found was if using two springs only, your throttle cable can't have any binding or you will find that your idle speed will vary on the high side, blipping the throttle when coasting to a stop can make the idle settle down. The weight of throttle peddle can cause this effect as well, I have a Hopkirk extender that really made things interesting. Just my experience.
Posted 06 December 2010 - 04:35 PM
How much was that extender terry?
Posted 07 December 2010 - 08:52 PM
Thanks but is there a clip for the choke cable to keep it in place like
the HS4 carb
the HS4 carb
Posted 08 December 2010 - 01:21 PM
I certainly agree you need a smooth operating throttle cable but if you haven't got one I'm not sure that the third spring will help. This is because if the throttle won't close smoothly without a third spring it is unlikely to open smoothly with the spring. If your throttle cable is sticky then bicycle brake cable is the way to go as the cable runs in a liner.
