Mini Tires
Posted 05 December 2010 - 09:32 PM
Posted 05 December 2010 - 10:44 PM
175 is the width of the tread in millimetres.
50 is the height of the sidewall as a percentage of the width
13 is the diameter of the wheel that the tyre goes on.
205/50/13 tyres will fit on the rim but they are a lot larger diameter than the current tyres. You'll also make the usual problems with 175/50/13 tyres even worse if you fit a 205 tyre. They grip very well in the dry but the steering is very heavy, it'll tramline like crazy, it will put lots of strain on suspension and steering components, it'll aquaplane at the first sign of condensation on the road etc... And that's assuming that they will actually turn under the arch without hitting things.
Iain
Posted 05 December 2010 - 10:49 PM
No. Learn how the tyre sizes are described and you'll understand why.
Iain
145 70 12's ftw! or even better 165 70 10's
But yes all the above is true, widen the tread and you will most likely make the side wall higher. Would have though they would be abit to wide like knuckleing out abit .
Posted 05 December 2010 - 11:11 PM
