Please Can Somebody Give Me A Quick Guide To Stripping My Engine?
Posted 07 December 2010 - 01:12 PM
I know the basic mechanics of an engine, but I just want to be sure I know what i'm up to.
If anybody can give me a rough guide, and a few tips and poiters, I'd be very grateful.
Thank you, Steve
Posted 07 December 2010 - 01:25 PM
Posted 07 December 2010 - 01:44 PM
Posted 07 December 2010 - 02:54 PM
Posted 07 December 2010 - 03:05 PM
Posted 07 December 2010 - 03:18 PM
take a picture of everything you take of put things into labelled bags and make notes of how they went together etc and what order things where in e.g washers nuts bolts etc
take yore time
anything youre unsure of ask on here about no matter how stupid you might think it sounds
oh and dont try to force anything too much
Posted 07 December 2010 - 03:49 PM
Posted 07 December 2010 - 03:55 PM
Posted 07 December 2010 - 04:06 PM
Posted 07 December 2010 - 04:41 PM
wrong haynes manual
You need the earlier light blue one... the later dark blue one tells you how to service and engine and that's about it. How useful...
Agreed... I have both - the resto manual is useless...
Posted 07 December 2010 - 05:47 PM
Posted 07 December 2010 - 06:48 PM
but bill solis ultimate mini dvd is very helpfull in the process.
Posted 07 December 2010 - 06:53 PM
What's wrong with it?
Posted 07 December 2010 - 07:13 PM
Remove engine/gerarbox from car.
Remove usual ancilliaries - generator, starter motor, manifolds, oil filter, water pump, etc.
Remove rocker shaft, push rods and cylinder head
Take off Clutch end cover (The 'Wok')
Lock flywheel with flywheel locking tool with pistons 1 & 4 at TDC
Remove clutch and flywheel assemblies (see haynes manual)
Remove transfer gear case (that's the big aluminium casting at the end of the engine into which the flywheel/clutch sits)
Take out the dip stick.
Undo all the small bolts around the edge wher4e the gearbox meets the block. Lift the block off of the gearbox.
Now strip the engine as follows:
Undo each big-end cap and push rods and pistons in turn through the top of the block. Re-fit the correct big-end cap to the correct big end and mark the rod number.
Remove the timing cover, the timing gears and chain and the cam retention plate. Remove the engine front plate.
Undo the main bearing caps and remove the crankshaft.
Pull the camshaft out from the front of the engine
Take out the cam followers.
Undo and remove the oil pump
You will now have a fully stripped engine and can come back on here for any re-build advice you may need. In fact, I have a 1997 MPI engine, completely stripped, on my workbence at the moment.
Good luck with the re-build.
Posted 07 December 2010 - 10:39 PM
