Battery Charging Problem
Posted 07 December 2010 - 10:29 PM
ive checked the connector to see if it was corred on the terminials of the battery and on the fins of the altanator
connector ive changedthe altanator aswell
has anyone got any ideas thanks chris
Posted 07 December 2010 - 11:43 PM
Does your no-charge warning light work? The alternator needs it to be able to switch on and start produing power.
Posted 08 December 2010 - 09:45 AM
and i tried reving it to see if the lights go brighter they stayed the same and cant test altanator till next week and cant buy one bacause im skint lol any other suggestions.
Posted 08 December 2010 - 10:36 AM
Whats the tension like on the fan belt?? it could be slipping if not tensioned correctly.
Posted 08 December 2010 - 01:05 PM
Posted 08 December 2010 - 06:40 PM
Posted 08 December 2010 - 07:35 PM
G
Posted 08 December 2010 - 08:09 PM
sounds like worn brushes to me especialy if the light comes on at high revs.
what about the brightness/volts difference with engine off and on, is there any?
check all your terminals for tighness and make sure they are all clean of corrosion/rust.
best bet is to get a new one, if it cures it then good, if it dont then atleast you know it will last for years to come and you can try and fault find the rest of the system.
Posted 08 December 2010 - 08:17 PM
Ran a new wire of suitable rating and hey presto, 14.5v at the battery
Posted 09 December 2010 - 12:30 PM
So does the warning light show when the ignition is on and the engine not running, or only when you get to high revs?
only with high revs mate
Posted 09 December 2010 - 01:35 PM
Posted 09 December 2010 - 05:46 PM
what is the yellow light for on the dash when i went around a corner quick earlier it came on then went off again ?
Posted 09 December 2010 - 07:00 PM
The no-charge light should show when the ignition is on and the engine not running, the fact that it doesn't but the bulb does work and lights up at high revs points to a wiring problem in the dash. The alternator is not working because it isn't able to sense battery voltage, it needs to in order to work and it does that through the warning light.
Posted 10 December 2010 - 04:11 PM
thanks chris
